BigJimnyMeet 2024
Air operated front hubs
- markyp2000
- Visitor
08 Jun 2013 19:33 #73199
by markyp2000
Replied by markyp2000 on topic Air operated front hubs
The vaccum puts them on it dont hold them on then the vaccum pulls them off
So if you put them on in 4wd then just take the pipe off the inlet manifold and thay should stay on then bung both holes up
- Thank you received: 260
08 Jun 2013 19:57 #73206
It's what I inferred after VAXXi's comment
Replied by helijohn on topic Air operated front hubs
markyp2000 wrote: The vaccum puts them on it dont hold them on then the vaccum pulls them off
but it is a matter of a novice to Jimny's like me locating the pipe's inlet into the manifold. I guess I only really need to seal off the inlet manifold pipe like with a bit of tube and a ball bearing or screw in it. The tube end from the hubs just needs protecting against dirt ingress!!Rear always on, front remains in the way it was when the vacuum system broke (if they were on, they stay on, if not, not).
- volkshome
- Visitor
08 Jun 2013 21:38 #73220
by volkshome
Replied by volkshome on topic Air operated front hubs
anyone got an exploded diagram as I am sure it could be done easily if its a sliding sleeve by either adding an additional sleeve to stop the slider returning or if maybe a simple spring to hold it in place?
I know with my jeep wranglers they have an vacuum operated system for the front axle and the reason jeep don't connect if to run all the time is both mpg and you can get vibration problems when the vehicle is travelling at more than 25mph-30mph as the need to turn the outer part of the drive shafts(steering) make them unbalanced at speed.
08 Jun 2013 22:09 #73224
by kirkynut
Replied by kirkynut on topic Air operated front hubs
Jeeps don't run CVs but use big UJs instead which I imagine would be out of balance. Cvs are fine as per normal front wheel drive cars. In fact freewheeling hubs were only an option on SJs and Vitaras. A popular one mind.
I have some old vacuum hubs I keep meaning to look at to see how the vacuum system works. If I get time this set of rest days I'll spend some time looking at them. I've not bothered before other than for a few seconds when they came off because I'd got replacement freewheeling ones and fixed ones to choose from.
The following user(s) said Thank You: helijohn
09 Jun 2013 09:04 #73236
In the past whenever I have had (selectable) freewheeling hubs fitted I always left them in the locked position, rightly or wrongly, but never really noticed any adverse effects, in fact never really noticed.
I like the idea of removing the vac pipe as it is soooo simple (I need simple) - if I could find it. It's worse than spaghetti under there. Don't forget my last version of this was my 1985 SJ413 and even that had pipes everywhere.
- Thank you received: 584
09 Jun 2013 11:35 - 09 Jun 2013 11:42 #73254
by facade
Replied by facade on topic Air operated front hubs
Vacuum doesn't keep them engaged, just flips them from one state to the other. I think there are magnets that hold the position.
No doubt you could take them apart and put something solid inside to keep the moving part stuck in the lock position.
Edit: there is a magnet to hold the sliding collar inside the hub (free position the collar is away from the wheel) the out position (drive is maintained by spring pressure.
Last edit: 09 Jun 2013 11:42 by facade.
Time to create page: 0.094 seconds
