BigJimnyMeet 2024
235/85-16 on Stock Suspension, No Body Lift & All Original Panels
- Rabid Rhino
- Elite Member
- Thank you received: 32
20 Apr 2022 02:31 - 20 Apr 2022 02:48 #243003
by Rabid Rhino
Replied by Rabid Rhino on topic 235/85-16 on Stock Suspension, No Body Lift & All Original Panels
Time to finish this build.
Wheels. Tibus actually recommend a wheel supplier & size: 16x6.5 with a 59mm offset.
I went with a 16x7 still with the 59mm offset.
I wasn't expecting the price... 5 rims were over half the price if all 4 portals which make the Tibus boxes seem like a bargain..
plus there was a 2 month lead time for the rim manufacturer where as the portals were available immediately.
Most of my 4x4s have a theme. This one is no exception But I need to see how finances pan out. So close but still so far to go.
Apparently these beadlocks are street legal.
I do like the steel liners in the stud holes.
I was going for the RAF Rondel & hoping I could get the tyres off to MrWhitewalls for a dark blue wall but I ran out of time so just have to do it myself.
Last edit: 20 Apr 2022 02:48 by Rabid Rhino.
- Rabid Rhino
- Elite Member
20 Apr 2022 02:51 - 20 Apr 2022 02:52 #243004
by Rabid Rhino
The guys I bought the tyrex off were to afraid to mount them on my fancy rims incase they damaged them. Same for a couple of other places so in stepped Dean once again as friends of his had just got a new mounting machine.
Last edit: 20 Apr 2022 02:52 by Rabid Rhino.
- Rabid Rhino
- Elite Member
20 Apr 2022 03:01 #243006
by Rabid Rhino
Putting the wheels on the car i noticed the chamfer on the Braid wheel nut holes are way bigger that the stock Suzuki nuts so I called Braid who got a full set out in the mail to me. FoC.
- Rabid Rhino
- Elite Member
20 Apr 2022 03:05 #243007
by Rabid Rhino
- Rabid Rhino
- Elite Member
20 Apr 2022 03:09 #243008
by Rabid Rhino
This is the real reason I got the Portals...
Clearance. The kind to never fear landrover rutts ever again.
- Rabid Rhino
- Elite Member
20 Apr 2022 03:17 #243009
by Rabid Rhino
The real measure is the tale of the tape.
I got another tape and measured the total length.... 15.5"
Take off 0.25" for a slight bend as the tape was jammed in there under tension & you sill have 15.25" minimum clearance at the diff on 31.5" tyres.
- Thank you received: 1774
20 Apr 2022 03:26 #243010
Replied by Lambert on topic 235/85-16 on Stock Suspension, No Body Lift & All Original Panels
Very nice! Love the cheeky bit of tyre stick out, makes it look like something American on one tons.
The following user(s) said Thank You: Rabid Rhino
- Thank you received: 485
20 Apr 2022 07:14 #243011
Replied by Soeley on topic 235/85-16 on Stock Suspension, No Body Lift & All Original Panels
Looks great, nice work.
I had also read the Portals were a bolt-on kit, but if you have to weld and drill out holes, it's not really reversible if you wanted to put it back to standard to sell on.
- Thank you received: 653
20 Apr 2022 15:30 #243017
Replied by jackonlyjack on topic 235/85-16 on Stock Suspension, No Body Lift & All Original Panels
Nice amount of clearance gained
Looks like rears will rub.....are you going to fit longer rear radius arms and propshaft
looks good though well done
- Rabid Rhino
- Elite Member
21 Apr 2022 01:05 #243022
by Rabid Rhino
Soley...
A friend of mine recently broke a 1999 Jimny.
I bought both axles with radius arms, gearbox & transfer case for £400.
I wish I'd had the spare set to work on off the car first so the car wouldn't have been out of commission for so long..
Jack...
I think the rear needs to go back 2 or even 3"
I was thinking about new radius arm mounts behind the existing ones. Same for the Panhard & shock mounts. I even wanted to cut off the coil mount & move it as well.
Then Dean who did so much, stepped in & suggested coilovers for simplicity which I'm leaning towards.
Do the lifted radius arms move the axle back that much ? I wouldn't think they do as the coil stays put. I have seen some "S" shaped coils on some kits which I don't like.
I'm away from home right now but as soon as I get return... that axle is going back.
I'm sure 33s will fit.
I think even a skinny 35s may fisuggested. move the front axle forward 0.5 to 1" by redrilling the mounts as someone here suggested.
Jack...
- Rabid Rhino
- Elite Member
21 Apr 2022 01:17 #243023
by Rabid Rhino
- Rabid Rhino
- Elite Member
21 Apr 2022 01:50 - 21 Apr 2022 01:51 #243024
by Rabid Rhino
We couldn't see where they would go.... initially.. then found them in the instructions although no mention of them, just a pic.
I emailed the Tibus guys and they said that they're just to keep the axle shafts in place & doesn't matter that I missed them out & that they can stay out.
Bishop Bullwinkle says it best about how I feel about that answer.
youtube.com/shorts/-K7fCQlUhj0?feature=share
I think I can remove the whole outside of the casing with the hub still on.
Fingets crossed.
Fingets crossed.
Last edit: 21 Apr 2022 01:51 by Rabid Rhino.
