BigJimnyMeet 2024
235/85-16 on Stock Suspension, No Body Lift & All Original Panels
- Rabid Rhino
- Elite Member
- Thank you received: 32
17 Apr 2022 19:08 - 17 Apr 2022 21:06 #242947
by Rabid Rhino
Replied by Rabid Rhino on topic 235/85-16 on Stock Suspension, No Body Lift & All Original Panels
Last edit: 17 Apr 2022 21:06 by Rabid Rhino.
- Rabid Rhino
- Elite Member
17 Apr 2022 21:21 - 20 Apr 2022 02:55 #242954
by Rabid Rhino
Video of the internals working where you may see the 16% gear reduction.
Don't know how else to embed it so it comes up with a pic.
youtube.com/shorts/1gO0rQ4Mjw0?feature=share
Last edit: 20 Apr 2022 02:55 by Rabid Rhino.
- Rabid Rhino
- Elite Member
17 Apr 2022 22:30 - 17 Apr 2022 22:54 #242957
by Rabid Rhino
Rear hubs were stripped down to the axle and the 4 bolt holes in the axle flange had to be bored out for bigger bolt to accept an adapter plate & bearing carrier to take the rear face of the portal box.
Last edit: 17 Apr 2022 22:54 by Rabid Rhino.
- Rabid Rhino
- Elite Member
17 Apr 2022 23:37 - 17 Apr 2022 23:38 #242961
by Rabid Rhino
Front axle was pretty much the same as the rear except with extra parts...
lets call this a test fit.
Last edit: 17 Apr 2022 23:38 by Rabid Rhino.
- Rabid Rhino
- Elite Member
17 Apr 2022 23:39 #242962
by Rabid Rhino
- Rabid Rhino
- Elite Member
19 Apr 2022 00:16 - 19 Apr 2022 00:26 #242982
by Rabid Rhino
When on the car id seen the front axle had a little protection added to it but on the bench I saw a little more.
What the ?
With this being a Portugese car there's a Portuguese saying which translated is...
Leave the crap alone. The more you touch it ghe more it smells.
So I left these turds alone.
What the ?
Last edit: 19 Apr 2022 00:26 by Rabid Rhino.
- Rabid Rhino
- Elite Member
19 Apr 2022 00:47 #242983
by Rabid Rhino
Axle stripped down ir was time for welding then reassembly.
These rod ends fit ontop of the double ended kingpins. Nice bit of welding by Dean to lengthen them.
Eirhervthese where universal brackets or I think Tibus wanted us to mount them tge tenderize of the coil seats & along the trailing arm mounts us
A block that was in the kit (no idea why) was welded to the axle and so the gussets could bolt through it for easy removal & instal
- Rabid Rhino
- Elite Member
19 Apr 2022 00:50 - 19 Apr 2022 01:01 #242984
by Rabid Rhino
All jigged up.
This one sounds have gone near the top.
All jigged up.
Last edit: 19 Apr 2022 01:01 by Rabid Rhino.
- Rabid Rhino
- Elite Member
19 Apr 2022 00:56 #242985
by Rabid Rhino
- Rabid Rhino
- Elite Member
19 Apr 2022 01:12 #242986
by Rabid Rhino
Me dreaming of extra trusting.
I lost it for a while & just found it. I may put it on the rear axle.
- Rabid Rhino
- Elite Member
19 Apr 2022 01:23 #242987
by Rabid Rhino
Rear axle gussets weren't as complicated.
they were welded onto the axle to bolt onto the rear face of the portal.
- Rabid Rhino
- Elite Member
19 Apr 2022 01:41 #242988
by Rabid Rhino
Time to get this buttoned up.
it had been all go... now time to make it stop
Brembo.... sporty. No idea what the rear calipers are.
Kit came with ABS sensors which are no use on mine.
This was the most painful part of the build.
Cutting of perftly good pieces & binning them
Time to create page: 0.348 seconds
