BigJimnyMeet 2024
Furo's Jimny Build
- Thank you received: 653
22 May 2020 13:23 #222666
Replied by jackonlyjack on topic Furo's Jimny Build
Are you using correct coaxial cable and a spliter box for radio
22 May 2020 13:33 #222667
i use this cable
www.thunderpole.co.uk/cable/rg213-bx-coaxial-cable-black.html
I have dab radio with different aerial
are you using something like this
www.rightchannelradios.com/products/cb-am-fm-antenna-splitter
- Thank you received: 63
22 May 2020 13:45 #222668
by furo
Replied by furo on topic Furo's Jimny Build
Thanks Jack! Yes I'm using a similar splitter and I bought that exact coaxial cable. A coaxial cable runs from the radio to the splitter, then another coaxial cable runs from the splitter up to the radio mount on the roof (which has a built-in ground). I had hoped to attached the antenna directly to the original radio mount but it didn't fit, so I got another coaxial cable and joined the radio mount to a homemade antenna mount (just some washers and a M6 bolt that the antenna threads onto). So the whole length is coaxial cable apart from the join in the original radio mount.
So far I haven't been able to properly check it with anyone else who has a CB, but one thing that concerns me is there is absolutely no difference in my FM radio quality if I screw the antenna on vs leaving it as just the bolt! I don't know what that means.
22 May 2020 13:47 #222669
by furo
In this image you can see the bolt in the radio mount, to which I have attached a further length of coaxial cable. The cable runs to a bolt in the roof rack that I screw the antenna onto.
22 May 2020 13:56 - 22 May 2020 14:03 #222670
Sounds to me like you have made a direct short
between the centre core to the braid by going onto a bolt
they need to be separated by this kind of connector
www.thunderpole.co.uk/rf-plugs-connector...rg223-h155-type.html
this is the mount i use
www.thunderpole.co.uk/fixed-body-mounts/...stick-mount-kit.html
Last edit: 22 May 2020 14:03 by jackonlyjack.
The following user(s) said Thank You: furo
23 May 2020 11:54 #222734
by furo
Thanks Jack. I was careful to fold back the braid and used heat-shrink over it, so I don't think it has shorted with the centre core.
If the whole thing is disconnected I only get static on my FM radio. If I connect the cable to the roof rack without an antenna I get reasonable signal. If I add the antenna the signal is unchanged. So is the whole roof rack acting as an aerial? Sorry if these are stupid questions. Do I need to make sure the antenna is isolated from the roofrack?
23 May 2020 13:20 #222739
Should be connection from the braid to rack
No connection from centre core
23 May 2020 17:58 #222755
by furo
Ah right, I didn't realise that, thanks! I'll have to think about how to do that.
25 May 2020 14:59 - 25 May 2020 15:24 #222812
by furo
Thanks for the CB advice so far. My radio wasn't set to the UK, so I changed that, and I put in a rubber grommet to separate the antenna from the roof rack. I haven't worked out a way to neatly connect the braid to the rack yet.
Last edit: 25 May 2020 15:24 by furo.
04 Nov 2021 10:04 #239855
by furo
Unfortunately my Jimny failed it's MOT on extensive chassis corrosion and I couldn't justify the cost to have it all welded, so I had to sell it. I'm pretty gutted, but I'll get some sort of project vehicle again in the future.
I've made a highlight video of my ownership of the Jimny, just showing the modifications and some adventures.
Thanks for all the great advice over the years, this website has been a brilliant resource.
- Thank you received: 1761
04 Nov 2021 13:19 #239859
Replied by Lambert on topic Furo's Jimny Build
Sorry for your loss!
04 Nov 2021 13:27 #239860
by gv42
Replied by gv42 on topic Furo's Jimny Build
It was a sad day for you !
Time to create page: 0.150 seconds
