BigJimnyMeet 2024
Norwegian Jimny G16b
- Thank you received: 10
23 May 2017 06:49 #181448
by Mescort
G16B, Doug Thorley Header, Trail-Gear 6,5:1 Transfer, Front 28 Degree CV propShaft, Redacted crawler box kit, Zanfi 2" springs, Zanfi 10° + 10mm Front Radius arm, Caster Correction Bushes rear, Adjustable Panhard, Bilstein 5100 Shocks, Dotz dakar 15x7, goodyear duratrac 235x75x15, warn M6000
Replied by Mescort on topic Norwegian Jimny G16b
takk
Har du noe link eller info om eventene til KNA ?
- Iaitoo
- Visitor
23 May 2017 15:51 #181455
by Iaitoo
Replied by Iaitoo on topic Norwegian Jimny G16b
De er vel litt sånn fra og til. Facebook er best for info. Så poster de når de får tillatelse til å kjøre. Gruppa heter KNA Bodø Offroad
- MadsV
- Visitor
20 Aug 2017 18:02 #183512
by MadsV
Replied by MadsV on topic Norwegian Jimny G16b
Any chance getting the photos up again?
20 Aug 2017 19:08 #183513
by Mescort
Yes if I knew how??
- MadsV
- Visitor
20 Aug 2017 19:29 #183514
by MadsV
Replied by MadsV on topic Re:Norwegian Jimny G16b
You could email them to me at This email address is being protected from spambots. You need JavaScript enabled to view it. :)
I did this conversion on my last Jimny, planing to do it again so would like some inspiration!
- OlaGB
- Visitor
25 Mar 2018 17:42 #190858
by OlaGB
Replied by OlaGB on topic Norwegian Jimny G16b
Thanks for uploading pictures again!
Beautiful build, and has to be a very expensive one as well
05 Jan 2019 17:53 #200057
by Mescort
05 Jan 2019 17:54 #200058
by Mescort
05 Jan 2019 18:00 #200059
by Mescort
05 Jan 2019 18:04 - 05 Jan 2019 18:38 #200060
by Mescort
Last edit: 05 Jan 2019 18:38 by Mescort.
05 Jan 2019 18:18 #200062
by Mescort
- OlaGB
- Visitor
05 Jan 2019 18:59 #200065
by OlaGB
Wow, thats a proper update!
Changing lift kit due to approval reasons i guess?
And double lockers, love it! Running 22 spline and stock axles up front?
Did you have to grind alittle on youre front diff axle-opening, to fit the new locker? I had to, locker was a bit bigger than stock.
That tank looked scary low though, do you even need the tank? I dont, compressor keeps air pressure for 30min no problem without tank on mine..
Any wheel allignment done with the new lift kit? Wondering about castor angles with those correction arms on 50mm lift, compared to my correction bushes. I think more castor angle would be better on mine
Time to create page: 0.174 seconds
