BigJimnyMeet 2024
Norwegian Jimny G16b
- Thank you received: 552
05 Jan 2019 19:30 #200066
by Scimike
Replied by Scimike on topic Norwegian Jimny G16b
Thanks for the update. I love to see the work that goes on, top effort.
Any plans to protect what look like the pressure safety valve and drain tap on the tank? Whilst the tank will take a bash or two those items look like the first bit to get torn off. Hard to tell for sure what they are, just showing an interest in your work.
- Thank you received: 10
05 Jan 2019 19:39 - 05 Jan 2019 19:42 #200067
by Mescort
G16B, Doug Thorley Header, Trail-Gear 6,5:1 Transfer, Front 28 Degree CV propShaft, Redacted crawler box kit, Zanfi 2" springs, Zanfi 10° + 10mm Front Radius arm, Caster Correction Bushes rear, Adjustable Panhard, Bilstein 5100 Shocks, Dotz dakar 15x7, goodyear duratrac 235x75x15, warn M6000
Replied by Mescort on topic Norwegian Jimny G16b
Jupp chainging the lift kit because I needed tuv papers will switch back to bilstein dampers after approval. They are much better.
that's my opinion
No i didn't need to grind something off the diffhouse at the front jupp running 22 spline and stock axles front and rear.
The tank isnt scary low , the picture lying a little. dont need it but it is nice to have when I fill the tires after snow or mud driving (fun driving)
tested the locker over night and they went fom 4 to 3,5 bar so no leek.
wheel allignment
the correction arms are 10 degrees more caster and 10 mm longer than the stock one. had caster correction bushes before but the arms are much better
that's my opinion
wheel allignment
Last edit: 05 Jan 2019 19:42 by Mescort.
- OlaGB
- Visitor
05 Jan 2019 21:17 - 05 Jan 2019 21:19 #200070
by OlaGB
Replied by OlaGB on topic Norwegian Jimny G16b
Would love to test those shocks you run, as i feel the trailmasters also are doing a decent job!
Must be a minor difference in diffs or axles then, or maybe the gearing in the pre vvt models makes the main gear smaller and therefore better space to enter the axle. My housig needed a 5mm grind at 2 and 4 o`clock to make room for entering.
I had a 20L tank on a land cruiser once, but it took under 10sec of tire filling before the compressor ran constant. So i didnt bother installing any tank now..
Do you have youre wheel angle numbers available? This is mine, barely over lowest approved value on caster (not castor ofcourse lol).. Curious if youre caster still is within legal spec? I bet its better to drive with more angle, as i feel its a bit sensitive in the center, and does not straighten up by itself good enough for my taste. Expensive upgrade though..
Last edit: 05 Jan 2019 21:19 by OlaGB.
Time to create page: 0.111 seconds
