- Thank you received: 923
- Thank you received: 1761
S200KYS wrote: Hmmm, kinda decided that a buggy is not practical for the UK (unless I win the lottery, then I'd get a tricked up Polaris RZR*)
(*and as the other lads in the group have said, a Polaris or similar, doesn't have sufficient ground clearance for greenlaning... so KISS and keep it Jimny 2!)
A standard ranger comes with 12 inch of clearance how much more does one need? I know the suspension design puts the arms a lot lower nearer the wheels but even so a ranger will climb about over terrain that would make a unimog weep.
That's all for now on the red one though, I'll start it's own build thread on Sunday when I get back to working on it...
- gusthegorilla
- Thank you received: 190
S200KYS wrote: "SZOOKYS" little brother, as yet to be named, is taking shape... I'll start a blog and a build thread on it soon, as work progresses, but here's a teaser photo -
So far, suspension lift and 235/75/15 Maxxis MTs fitted...
More on the little red one soon!...
Damned good choice, Dave......wouldn't have one any other way ......
I'm planning to live forever.....so far, so good !!
- idiotmobil
- Thank you received: 118
JIMNYLESS
- Visitor
Looking good Gus
Have you got a window in the back hardtop section Gus?
Just planning mine...
idiotmobil wrote: Looks like you have done some thing a little diffrent with my roof at the rear and fixings
Looks like Gus has modded it so the rear tailgate opens with the roof in place?
oooh, might copy that!
- idiotmobil
JIMNYLESS
- idiotmobil
JIMNYLESS
- gusthegorilla
That's exactly what I did. ...located the pull-down fasteners on the inside for added security, transferred the door measurements to the bottom edge of the roof and cut out 1", fitted a flexible rubber seal in place of the bit I removed so that when the door opens and closes it just displaces the rubber as it goes by, but provides a weatherproof seal for the door when closed.
Thought about fitting a window (had one available until recently ), but decided against it purely so that the stuff I keep inside is much less visible.
One thing I should mention....when I cut out the 1" bit from the bottom edge, the roof lost some of its inherent strength, so I fabricated a lightweight aluminium stringer the width of the roof and bonded it to the inside....rigidity and strength restored
This thread is for Big Blu'
