BigJimnyMeet 2024
The SJ413, SJ410 and SJ510/2 trailer of the Yakuza
- Thank you received: 479
06 Feb 2023 21:46 #247396
Replied by Soeley on topic The SJ413, SJ410 and SJ510/2 trailer of the Yakuza
Nice job!
- Thank you received: 1761
07 Feb 2023 04:23 #247398
Replied by Lambert on topic The SJ413, SJ410 and SJ510/2 trailer of the Yakuza
This is going to end up too nice to sell!
- Thank you received: 332
07 Feb 2023 07:44 #247399
Oh I know, but where to put it?
Replied by yakuza on topic The SJ413, SJ410 and SJ510/2 trailer of the Yakuza
07 Feb 2023 19:59 #247421
Small test run as the rear axle, exhaust, tank and rear brakes (again) had to be tested. When grinding the rear axle I cut the brake line so had to change that. Still too much air in the brake lines, most likely up front.
And still some strange noises to investigate. I am thinking maybe something got too much play. steering box, rod ends, king pin bearings dunno.
Got all those in stock so no too worried. Not ready for the MOT quite yet. But getting closer.
07 Feb 2023 20:30 #247426
You wanted to know where to keep it when you're done and the obvious answer is in the garage ready for lazy summer afternoons with the top down.
14 Feb 2023 13:07 #247609
14 Feb 2023 21:05 #247624
Great news!
01 Apr 2023 13:13 #248343
01 Apr 2023 14:06 #248344
I have a question. You have 235s and a 17pc reduction set. So you have an overall reduction of around 7pc. I know that the manual and automatic are different, around 500 rpm lower in the automatic at 70, and you can't make a direct comparison but how do you find the overall drivability especially in high range?
01 Apr 2023 15:11 #248345
Wrong thread
But the other Jimny is ok as a daily but a little high revs for the highway. It is fast up to 90 kmt but 3500 ish rpm in 90 - 100kmt. Haven't written it up so not sure if i got the figures right.
But for me that is ok. It is a 5 hour drive from Here to find a road with 110 kmt speed limit.
Also if I use the money I get for the 410 here to buy brettakantar (iceland flares) I might get some 30 or 31" tires. Then it might be ok.
01 Apr 2023 15:57 #248346
Apologies. Sorry, it's been a long week.
12 Apr 2023 12:59 - 12 Apr 2023 13:03 #248523
Just got this sudden urge to show my SJ from 15 years back, sorry if I allready did.
40(or 50mm bought used) OME lift springs, Volvo or Shogun or Corsa shocks (do not repeat that!) , 2" home made Body lift, home made flat belly bash plate, 8" wheels 325-65-15 BFG MT, cut out 3" of the fenders, bushwacker flares. many different G13 engines with various carbs, lastly a '92 engine still got it. Home made 4,16 :1 transfer gears. "Opel" Recaro seats.
Did the rust in the fenders, did the sills, but got kids so did not get around to do the body mount rust so got scrapped as it had too many none-approved mods. Ripped for parts, got most of it still.
Last edit: 12 Apr 2023 13:03 by yakuza.
Time to create page: 0.172 seconds
