My Jimny flat deck build - South Africa overlanding idea
21 Jan 2023 13:34 #247062 by Soeley
Very neat install, I think it looks brilliant.
Good work.
The following user(s) said Thank You: lookonimages
21 Jan 2023 17:48 #247067 by Lambert
Nice.
21 Jan 2023 21:21 #247072 by yakuza
Nice to see when details are this good, thanks for alot of ideas to do it nice and great with the pictures and explaination of how it is fastened.
I made two dog cages to fit inside my VW T4 and T5, and now my T5 is a camper. but nowhere near as good a job as this, but does not rattle and is removable.
I too used the pull down latches you did. when they get loose they can be tightened wich is nice. cause things will wobble and come loose after a while.
22 Jan 2023 18:34 #247092 by Roger Fairclough
I built my own box but as mine has a MDF floor, I don't have as much room as you. Also the UK model has as standard a separate plastic box that sits on top of the jack and wheel brace. The elasticated tie down is attached to a home made frame made out of plumbers copper pipe and various oddments.
Roger
22 Jan 2023 18:36 #247093 by Roger Fairclough
PS
The net can be removed and used to cover and hold shopping etc placed on the lids of the box.
Roger
24 Jan 2023 11:10 #247143 by saxj
Roger
Depending on the model, we get the plastic box that sits on top of the jack. The polystyrene moulding wastes a lot of space.
Time to create page: 2.978 seconds
