Light Bar vs Driving Lights
- 9800shane
- Visitor
I do even amount of road and offroad driving so I am after a lighting solution and I could swing either way.
I have narrowed it down now to which is going to look better on my bullbar.
Let's post up some pics or your lighting setup??
I would be looking at a 20" light bar or LED driving lights.
- Smoggy
- Visitor
Rhinoman wrote: A lightbar isn't legal for road use so you would be better off with driving lights.
Is it okay to have a lightbar wired through a separate switch so that you can use it when offroad do you know?
- Visitor
- StealthJimny
- Visitor
Smoggy wrote: Is it okay to have a lightbar wired through a separate switch so that you can use it when offroad do you know?
Technically no, it should be wired so it only comes on when the ignition is off, however I've never heard of anyone being prosecuted for it. As long as it doesn't come on with the main beams then it doesn't usually raise a comment. You can also get a ticket for not having 'E' marked lights.
All high level front lighting must be mounted forward of the front axle, that why its OK on a truck.
Thank you Jez
It's been fettled just a tad.
- skywalker65
- Premium Member
- Thank you received: 20
If in doubt ...... Flat out ??
