Re:Re:Best Tuning program to start tuning?
23 Sep 2022 15:03 #245080 by Vandoni
So, I've been wanting to change some values in my stock ECU and in the meantime learn a little bit about tuning, but I know nothing of the basic things that I need to start.
what is the best program to start tuning the ECU? And what should I buy in regards to the obd2 interface and equipment? (I have a laptop to work on obviously)
23 Sep 2022 15:24 #245084 by Lambert
I could be wrong as this is not my area of expertise but the stock ECU is not readily tuned. That would require something like a Haltec or Link or similar standalone unit. There may be specialist outfits that have cracked the factory one for some parameters but I'm not aware of it being a DIY option?
23 Sep 2022 15:30 #245085 by jackonlyjack
Lambert is correct the standard ecu is what it is
You can get numerous stand alones
Easiest way to gain power is from an engine swap to M16A
23 Sep 2022 18:00 #245087 by Vandoni
So what you're saying is, it's not certain whether I can unlock the stock ECU?
if that's the case do you know any cheap aftermarket ones that I could use?
23 Sep 2022 20:56 #245091 by 300bhpton
lol. Unlock it to do what? A song and dance routine :D
24 Sep 2022 06:44 #245092 by mlines
I think
www.rhinopower.org/index.html have investigated the stock ECU as far as it can go
Sent from my moto g42 using Tapatalk
Time to create page: 0.270 seconds
