BigJimnyMeet 2024
Fitting a Turbo or Supercharger to Gen4
- cumming
- Visitor
22 Jun 2021 13:43 - 23 Jun 2021 10:33 #236041
by cumming
Fitting a Turbo or Supercharger to Gen4 was created by cumming
Hi
ok so you can get a Greddy Turbo kit or Rotrex supercharger for your Jimny, yeah I really like the idea and have spoken to several performance specialists, who all tell me they couldnt fit either as they wouldnt be able to remap the Ecu .Can anyone give me any advice, I have uprated my exhaust and air intake but the Jimny is still very flat at the top end . Seems very difficult to get any kind of power upgtage in the UK other than a remap which will give you 10bhp and 11nm for around 300 quid , I dont think it would be noticible.
Regards Cam
Regards Cam
Last edit: 23 Jun 2021 10:33 by cumming. Reason: Typo
- Thank you received: 552
22 Jun 2021 14:04 - 22 Jun 2021 14:04 #236042
by Scimike
Replied by Scimike on topic Fitting a Turbo or Supercharger to Gen4
Hi Cam,
I totally admire those that want to improve the Jimny Engine performance, and I am not saying it can't be done, but you are entering a money pit with very limited returns. I must be one of the harder engines to modify, simply as you cant easily change the mapping etc, and experience in doing such work on this engine is very limited.
Most go for the "bigger engine" approach to gain more performance.
Some nice work done on here by a few that have resulted in (actual dyno, not feel) improvements, but it tends to be a lot of work beyond most home mechanics.
Not trying to be a fun sponge, just what I have seen.
Good luck and have fun
Mike
Mike
Last edit: 22 Jun 2021 14:04 by Scimike.
The following user(s) said Thank You: cumming
- Thank you received: 77
22 Jun 2021 17:44 #236051
by lightning
Replied by lightning on topic Fitting a Turbo or Supercharger to Gen4
l would say the Jimny would struggle to put that amount of power down without wheel spinning like a radio controlled toy.
You'd have to have it in 4wd which would generate further issues with transmission wind-up.
- lookonimages
- Thank you received: 64
22 Jun 2021 20:32 #236058
by lookonimages
Replied by lookonimages on topic Re:Fitting a Turbo or Supercharger to Gen4
- cumming
- Visitor
22 Jun 2021 21:31 #236060
by cumming
Replied by cumming on topic Re:Fitting a Turbo or Supercharger to Gen4
Thanks for the video I want !
- Thank you received: 320
22 Jun 2021 21:54 #236061
by Gadget
Replied by Gadget on topic Re:Fitting a Turbo or Supercharger to Gen4
The company in Aus that fits the Rotrex charger fits a piggyback ECU rather than remapping the factory ECU - although I believe they're working on custom maps for the stock ECU as well.
- Thank you received: 35
22 Jun 2021 22:11 #236063
by crash486
Replied by crash486 on topic Re:Re:Fitting a Turbo or Supercharger to Gen4
Since the new 5 door is getting a 1.4l turbo, it may be easier to do an engine swap or see what's done with the equipment when it's released.
crash486 JB74W
crash486 JB74W
23 Jun 2021 07:24 - 23 Jun 2021 07:24 #236066
by lightning
Replied by lightning on topic Re:Re:Fitting a Turbo or Supercharger to Gen4
My post was lost in the discussion.
I assume the Jimny will need to be in 4wd mode to put down that kind of power safely?
Last edit: 23 Jun 2021 07:24 by lightning.
- Thank you received: 169
23 Jun 2021 08:42 #236068
by 300bhpton
My 4.0 litre 190hp Jeep XJ could be RWD and was fine for the most part. Modern Wranglers are also RWD for road use in some guises and they have more power than a modded Jimny.
Replied by 300bhpton on topic Re:Re:Fitting a Turbo or Supercharger to Gen4
Not sure it would. Plenty of RWD cars about.My post was lost in the discussion.
23 Jun 2021 08:50 #236069
by 300bhpton
As for forced induction. If people are offering these as kits, they must have a way of controlling the fuelling?? Do you have any links to the kits you've seen?
Also if other companies are claiming to be able to 'remap', what are they doing that can't be done with FI?
As for doing this to a Jimny...... I'm a bit torn. I love modding vehicle (some of mine are very heavily modded). But I'd guess a forced induction kit on a Jimny is likely to set you back £5000+ and at the end of the day, even at 100bhp/litre, you'll only be looking at 150hp, although probably a good hike in mid rpm torque.
I'm not saying the Jimny couldn't handle this power. But it is a lot of money to spend for the return.
If you want a more speedy 4x4, the Jeep Wrangler can be had with more powerful engines (3.6 V6 with 286hp, 2.2 turbo petrol, 2.2 turbo diesel) and takes a remap well.
Replied by 300bhpton on topic Fitting a Turbo or Supercharger to Gen4
The stock engine shouldn't be flat at the top end. It is quite a revvy little sucker. Not sure where Peak power occurs, but it doesn't nose over at all, which is really odd and rare in 2020/2021. Ultimately it isn't hugely powerful, although its power to weight ratio isn't actually that bad overall.Hi
ok so yyou can get a Greddy Turbo kit or Rotrex supercharger for your Jimny, yeah I really like the idea and have spoken to several performance specialists, who all tell me they couldnt fit either as they wouldnt be able to remap the Ecu .Can anyone give me any advice, I have uprated my exhaust and air intake but the Jimny is still very flat at the top end . Seems very difficult to get any kind of power upgtage in the UK other than a remap which will give you 10bhp and 11nm for around 300 quid , I dont think it would be noticible.
Regards Cam
23 Jun 2021 09:04 - 23 Jun 2021 09:08 #236070
by lightning
Also the Wrangler is quite heavy so has plenty of weight over the rear wheels. The Jimny only weighs as much as a packet of crisps.
Best of luck controlling 150bhp through the back wheels on a Jimny in the rain.
Of course if you could some sort of centre differential that would make all the difference, but it would be a very difficult and expensive task.
Better to sell it for the mad money these are currently making, and buy a Wrangler SWB.
The 2.0 petrol version delivers 268bhp and the diesel is 200bhp
Last edit: 23 Jun 2021 09:08 by lightning.
- cumming
- Visitor
23 Jun 2021 10:25 - 23 Jun 2021 10:31 #236071
by cumming
Replied by cumming on topic Fitting a Turbo or Supercharger to Gen4
Thankyou for your advice, Bullet cars of australia supply the superchatger and Greddy do a turbo kit (trustpower.com) I guess i am trying to relive my days of a 400bhp series lightweight , just love that awesome power. I thought power pimping the Jimny would be easy . I love its off road capability and the fact its so small.
Kind regards Cameron
Last edit: 23 Jun 2021 10:31 by cumming.
Time to create page: 0.172 seconds
