Not sure what this is?
- Reason2doubt
- Thank you received: 100
In the middle of a small job and ended up removing the following item:
I'm not completely sure what it is... I did a search on the part number which seemed to indicate '4x4 canister' which has me thinking it is something to do with the vacuum system (but I could be completely wrong).
This made me wonder, can I remove it all together seeing as I have manual hubs now? If so - does anyone have any advice on what to do with the two pipes going into it?
Thanks in advance & sorry for the simple question. Kind of prefer to hear it from someone on here for confirmation...
- Jcg1694
- Visitor
- Thank you received: 1761
- Reason2doubt
Lambert wrote: Yes it is the vacuum can. Unnecessary if you have manual hubs.
Cheers mate! Always nice to have it verified by someone.
Doesn't look like anything to do with the vac system, the small vac tank that lives behind the wing only has one pipe to it.
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
This is a vacuum reservoir (image stolen from the internet)
I would expect ECU issues if its removed (its gone on mine, but mine is running aftermarket ECU, intake, etc).
- Reason2doubt
Better find the item in question and put it back....
Yes single cam early Jimny.
Thank you Riccy!
- Thank you received: 923
Here it is dangling as all the outer and inner wings have been removed, so I need to make a mount for it that will stand on top of the spring cup on the chassis...
Mine too has two small rubber hoses that run into the fuel intake area...
And I'm in the middle of adding a hose and breather tube to the port in the bottom of this "charcoal canister" as it vents to the atmosphere?
- Reason2doubt
@X8GGY - I noticed that too. I spent a little bit of time trying to figure out if there was a pipe somewhere which had possibly fallen off but it does appear to just be left with nothing attached.
Indicating the bottom 'port' is vented to the atmosphere... and could possibly fill with water if the vehicle was submerged for a long period of time, hence why I thought I'd add it to my breather setup...
