Anchor points to secure luggage/shopping etc in the boot.
- Thank you received: 21
- Thank you received: 328
But I would be careful not to overload the bolts as they are supposed to save your life in a crash..
In my country I would remove them before the MOT as well.
Edit: on the other hand, something heavy in the rear that comes flying forward when you crash would be considered unhealthy as well..
- Thank you received: 96
- Grima
- Visitor
- Grima
- Visitor
wjamieson wrote: Fitted some anchor points today to allow me to secure items in the back. Tend to use my car as a two seater all the time. I have the seats folded flat and the rubber boot liner. Even with the rubber boot liner things still tend to roll about in the back. Trying to find somewhere at the front proved difficult so decided to go with the anchor points for the seat belt. Removed the 14mm bolt and fitted the Tie down anchor hooks. Plenty of length in the bolt so no problem fitting the anchor hooks. Only slight challenge was removing the castellated washer(sure it has another name) need to use small screwdriver to prise away once removed a wee bit was able to unscrew like a nut. 10 minutes later two very strong anchor points that can be used to tie things down. Items bought from Amazon - QLOUNI 8PCS Tie Down Anchors Hook V-Ring Trailer Forged Lashing Rings Bolton Trailer Anchor Replacement, D Ring Dee Rings for Boats Vans Trucks Warehouses,...
This is also a threaded anchor point.
- Barry silver SZ5
- Senior Member
- Thank you received: 5
Barry silver SZ5 wrote: The red circled anchor half way up behind seats , I tried lifting off plastic grommet but it stays firmly in place Nothing on it to screw it off either like all the back and side plugs. Do I use more force as don’t want to break anything. I brought stainless u clamps off eBay from China as used by canoeists Very cheap.
Although they don't have the slots in, they are still the same as the others. The shafts are ribbed. A little more force removes them. They have the same thread as the other holes.
- Barry silver SZ5
- Senior Member
- TillymintDLG
- Visitor
I will see if the plug on the side of the center console also covers a threaded hole, if I could fit an anchor point there too I would have the four corners anchored
Former owner of JB43 (4sport BR trim) for 6 years/200,000+ km
Currently own auto JB74 since Aug-21 (50,000 km)
- OME kit (coils, shocks, panhard bracket and caster correction)
- front PPF to avoid paint chips
- rear custom deck
- Audison/Hertz sound system
