BigJimnyMeet 2024
Jimny Gen 4 Diff Breathers?
- lookonimages
- Thank you received: 64
29 May 2021 15:39 - 29 May 2021 15:45 #235466
by lookonimages
Replied by lookonimages on topic Re:Jimny Gen 4 Diff Breathers?
Last edit: 29 May 2021 15:45 by lookonimages.
- Thank you received: 70
29 May 2021 16:35 - 29 May 2021 16:36 #235469
by lightning
Replied by lightning on topic Re:Jimny Gen 4 Diff Breathers?
Looks a nice kit but,
Does it need differential breathers, are they not fitted as standard?
Last edit: 29 May 2021 16:36 by lightning.
29 May 2021 17:03 #235470
by Dan
Replied by Dan on topic Re:Jimny Gen 4 Diff Breathers?
Yes, the vehicle needs them.
I had mine done recently. Otherwise the wading depth is something ridiculous like 30cms from memory.
- lookonimages
29 May 2021 18:54 - 29 May 2021 20:07 #235474
by lookonimages
Std you cand wade through 30cm water or it will suck in water if water is higher then breather point
Diff oil an water is not friends.
So most people that do a little more adventurous stuff lift the end cap much higher by rooting it to highest point in engine bay. More likely you then can easlily go through 4 feets of water.
The realexperts take it upinto in snorkel and can go throuģh 5feet
Replied by lookonimages on topic Re:Re:Jimny Gen 4 Diff Breathers?
They are fitted as std but sit above the axle. This set move them higher to enable you to go through deeper water as end point is high in engine bay.lightning wrote: Looks a nice kit but,
Last edit: 29 May 2021 20:07 by lookonimages.
29 May 2021 22:52 #235475
by lightning
Replied by lightning on topic Re:Re:Jimny Gen 4 Diff Breathers?
Well, that's a good idea then.
l may order a kit for ours.
- Roger Fairclough
- Thank you received: 194
30 May 2021 11:13 #235481
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:Jimny Gen 4 Diff Breathers?
If you are using fuel/oil resistant rubber hose and you feel it may kink then I would suggest you use an internal coil spring ( I used stainless steel ) to prevent this happening.
Roger
Roger
Time to create page: 0.132 seconds
