- Forum
- Suzuki Jimny
- Jimny Technical
- Removing the Spare Wheel & Mount on a Gen 4 2019 Jimny: Now a Cleanskin!
- Thank you received: 1801
- Thank you received: 512
Where will you keep the spare, inside the car?
- Andy2640
- Visitor
In fact, ive seen the dealer model sat without the spare wheel, and just my opinion - It looks weird and not quite right.
- MrPaynterZA
- Visitor
It seems guys just have a naked rim mounted back there presumably because the tyre won't fit and would also block vision.
A rim would bolt right up and be smaller thus presumably out of sight?
- Thank you received: 923
www.jimnybits.com/jimny/jimaccessories/s...eel-spacer-5654.html
But to move the spare wheel down rather than up?
That spare wheel carrier looks like it could be flipped? and then the above spacer could be used on it to move the spare wheel DOWN...
Perhaps ask JimnyBits if they could try it first before you order?
- cyberdriver
- Visitor
- mikeyw85
- Visitor
Or, I did see a cover like the one you found for the 3G, but i'm sure it was for the new 4G. Possibly just on Instagram, but will try find it.
- mikeyw85
- Visitor
GeorgeC wrote: The camera display is a little different to your UK Displays, no grid/guide lines and a wider camera angle.
The guidelines can be switched on or off. While the camera is on, press the settings button, from there you can adjust Contrast, Brightness and Guidelines.
- anashe021
- Visitor
- Forum
- Suzuki Jimny
- Jimny Technical
