Removing the Spare Wheel & Mount on a Gen 4 2019 Jimny: Now a Cleanskin!
20 Mar 2019 09:34 #204837 by X8GGY
In act looking at your original photo -
That spare wheel carrier looks like it could be flipped? and then the above spacer could be used on it to move the spare wheel DOWN...
Perhaps ask JimnyBits if they could try it first before you order?
  • cyberdriver
20 Mar 2019 22:27 #204862 by cyberdriver
You might want to look into the legalities of number plate reading angles before lowering the spare. I vaguely recall it had to be readable from 45 degrees for those pesky overhead speeding cameras. Not sure if that was just QLD though. Perhaps solved by lowering the number plate and letting air out of the spare. The same applies if you fit a larger tyre.
  • mikeyw85
26 Mar 2019 16:10 #205101 by mikeyw85
you can take the bracket off and just have bolts.
Or, I did see a cover like the one you found for the 3G, but i'm sure it was for the new 4G. Possibly just on Instagram, but will try find it.
  • mikeyw85
26 Mar 2019 16:15 #205102 by mikeyw85
01 Apr 2019 19:36 #205382 by Soeley
GeorgeC wrote: The camera display is a little different to your UK Displays, no grid/guide lines and a wider camera angle.
The guidelines can be switched on or off. While the camera is on, press the settings button, from there you can adjust Contrast, Brightness and Guidelines.
  • anashe021
16 May 2019 09:12 #208103 by anashe021
Hey, You Can Visit at classiclift.com.au/ For buy car stacker
Time to create page: 0.298 seconds
