Jimny eats front wheel bearings
12 Jul 2018 19:24 #194246
Jimny eats front wheel bearings was created by mlines
Young customer has a Jimny that eats front wheel bearings. Both sides last only a few weeks.
Wheels are standard size, no spacers. Visually things look straight. No leaking oil from Swivels.
Bearings when removed are totally wrecked. The one he brought for me to see was exploded, on a previous one the balls were squared off.
He just arrived tonight to buy another bearing having been here 3 weeks ago. Both front wheels are very hot on the hubs, almost too hot to touch when he arrived. One bearing is only 3 weeks old. They have tried adding grease on installation.
Genuine Koyo bearings.
Any ideas where to look ?
- Thank you received: 1627
12 Jul 2018 19:35 #194247
Replied by Lambert on topic Jimny eats front wheel bearings
Brakes binding on and boiling the grease out of the bearings, possibly?
12 Jul 2018 19:57 #194248
Replied by mlines on topic Re:Jimny eats front wheel bearings
I thought of that one as well but he says brakes on at least one side were rebuilt recently so one side should be ok
12 Jul 2018 20:04 #194250
Replied by Lambert on topic Re:Jimny eats front wheel bearings
They are being pressed in square into suitably clean hubs? Is the car consistently being used hard off road in deep runny mud?
12 Jul 2018 20:06 - 12 Jul 2018 20:09 #194251
by Dano0404
Replied by Dano0404 on topic Re:Jimny eats front wheel bearings
Over tighten bearing? Thrust on the bearing? Ware on the shaft or housing?
If both sides are going it’s more than likely a fitting error.
Last edit: 12 Jul 2018 20:09 by Dano0404.
12 Jul 2018 20:21 #194253
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Jimny eats front wheel bearings
Is he doing them up with a torque wrench to the specified torque, or just a rattle gun?
12 Jul 2018 20:22 #194254
I was thinking that. Notwithstanding that your time is precious to you Martin, could it be worth fitting them yourself or by a respected fitter to rule out any fitting errors? I know it is not your problem as a supplier of the bearings to fit them correctly but either the car is damaged and won't be able to take new bearings without further repair or whoever is fitting these bearings is doing something quite wrong.
12 Jul 2018 20:33 #194255
by Jezz
I would also be asking how is he installing them, Pressed in? or punched in using a drift and hammer? Does he understand which part of the race to put pressure on to push them in, rather than just beating them in with a misaligned drift on the center of the bearing. (sorry if i'm teaching the fellow to suck eggs)
- Thank you received: 521
13 Jul 2018 10:21 - 13 Jul 2018 10:22 #194258
by facade
Replied by facade on topic Jimny eats front wheel bearings
You can't really apply too much preload without insane amounts of torque, as the preload is set by the split in the inner race closing up, then you'd have to compress the whole of the inner race.
It can only really be down to hammering them in, or pressing on the wrong part which dents the races- brinelling, or overheating them which anneals the bearing- you'd see the colour change and the wear marks. The failed bearings need careful examination.
It could be a manufacturing defect with the bearings, or some fakes may have got into the supply chain I suppose. If the bearings weren't hardened properly they'd wear in no time
Here is a nice article on bearing failure
www.schaeffler.com/remotemedien/media/_s...g_failures_us_en.pdf
Last edit: 13 Jul 2018 10:22 by facade.
- NIKOS OETA
13 Jul 2018 18:51 #194269
by NIKOS OETA
Jimny 1.3VVT/ 5" Zanfi Custom Suspension / 2" Body Lift / 31" Maxxis Trepadors+31" BF KO2/15X8 -40 wheels / -27% Transfer / Smittybilt 10.000 X2O Gen2 Comp Whinch / Custom Trasfer Skid and mounts / Veanted Discs + Vitara Calipers/ Led H4 Headligts / 120w Led Bar + Led Work+fog Lights / Yaesu 8800
Replied by NIKOS OETA on topic Jimny eats front wheel bearings
I had the same issue with one side bearing. After a lot of search, it caused by crooked hub, also the abs light came on after 110kmh. After changing the hub both problems solved.
- Thank you received: 151
15 Jul 2018 12:38 #194295
by mickt
Replied by mickt on topic Jimny eats front wheel bearings
What is the history of the car with this owner? has he just got it or ran it for a fair amount of time before he replaced them and if so why did he replace them then?
- Tr3nksJb43
31 Jul 2022 16:50 #244331
by Tr3nksJb43
Replied by Tr3nksJb43 on topic Jimny eats front wheel bearings
I just got myself a 2017 Jb43 model. Got replaced my rear bearings 2 times (once in the dealer) in a week. Note that I barely go offroad and never even dipped my toe in mud or sticky situations yet. Just 10 or 20 miles on a regular dirt road kills my bearings. Also same is happening on the front axle. Never ever in my life have I encountered these bad-bearing issues. Just got canceled my second tour to countryside due to bearing issues again...
Time to create page: 0.327 seconds
