Snorkels
14 Apr 2009 14:48 #584
Replied by mlines on topic Re:Snorkels
I forgot to say - in order to ensure my financial well being you may see me advertising them on E-Bay for slightly more - thats the benefit to you of being on this forum
14 Apr 2009 18:48 #585
YOU CAN ORDER NOW!!!
OK - so I am a beginner at this webshop lark. So please bear with my and be assured that if any problems occur with the software that I will sort it and only charge the correct amount.
- Thank you received: 34
14 Apr 2009 19:06 #586
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
Replied by ooky_123 on topic Re:Snorkels
Ordered and paid for.
Hubby is happy to collect .. were only down the road
19 Apr 2009 17:28 #604
by ooky_123
Right, today was dedicated to fitting the snorkel. Instructions were spot on, but its a little hard to find a 81mm hole cutter for steel, and after blunting Hubbys wood hole cutter, we decided to chain drill and then file the hole.
Snorkel went on really easy, and, aside from the studs needing to be fixerd to the body of the snorkel using superglue and a trip to Wickes to buy black silicone, the snorkel was fitted with out any issues. All bolts were sprayed with WD40 30 minutes before commencing work and all were removed with ease. Forget the storys about not being able to fit the nuts inside the wing, Hubby's new Halfords Professional ratcket ring spanners made light work and, once the snorkel was offered up and checked for alignment, was soon fitted using liberal blobs of black sealant.
Refitting was just as easy and quick and the whole job, including refitting topok no more than 2 hours.
Pix to be uploading in a while.
The end result is a really throaty intake roar when revved to 3000rpm and this continues as you accelerate. The snorkel adds to the chunky look of the jeep and, with the soon to be added roofrack and quad light bar will finish the pint sized mighty offroader nicely.
19 Apr 2009 17:45 #605
by ooky_123
PIctures..
Marking out..
Holes punched and drilled
First Fitment
Final Fit
Just need to pay attention to detail now. Give the wing a good polish and then run a small bead of black silicone around the join to finish it
Marking out..
First Fitment
Final Fit
19 Apr 2009 18:30 #606
Thats looking good - I hope its the quality you expected. Now you should be able to tackle water with a bit less worry.
Have you decided which way around the intake is going to be?
Mine, which is not a "proper" one like this but is a KAP Suzuki homemade one, also roars with induction noise as you accelerate. I quite like it but if you find it too much there are some suggestions from guys in Australia (where the snorkel comes from) on www.jimny.se about quietening the induction roar.
