Dash showing engine temp is realy hot! NOW SOLVED!
  • Nobby22
26 Nov 2011 12:53 #26625 by Nobby22
Replied by Nobby22 on topic Re: Dash showing engine temp is realy hot!
kirkynut wrote: Do you have the single or twin cam engine mate?
Its a 16v so i assume its a twin cam?
  • Nobby22
26 Nov 2011 13:02 #26626 by Nobby22
I have just had a look at the manual ( thanks keefe ;) ) and it seems fairly straight forward to remove the intake manifold. Not a quick job but with it all written down it makes it seem fairly simple, no technical tasks just un-bolt and un-plug. Hmm... do i have a go or not? Mind you its not a case of "have a go" more like " i carnt cock it up" :laugh:
Nobby
26 Nov 2011 13:03 #26627 by kirkynut
Nah, they're all 16v. What's the start letters of the engine no on the registration doc? Or post a piccie of you engine.
  • Nobby22
26 Nov 2011 13:17 #26628 by Nobby22
:blush: I dont tend to like to do much with the engine, hense my lack on knowledge :blush:
Starts with M13A
Attachment IMG_0001_6.jpg not found
I can take another one if this is no good. Its one i took a while agao to show the air horns.
Nobby
27 Nov 2011 21:55 #26762 by kirkynut
Nobby22 wrote: :blush: I dont tend to like to do much with the engine, hense my lack on knowledge :blush:
Starts with M13A
Nobby
You have a twin cam engine driven by a chain and not a belt - Hurrah!!!
I looked at mine today as I was working on it and looking at it I would have guessed that the thermostat was on the end of the block at the front of the car where the hard coolant pipe bolts to it - in your picture look to the right hand end of the rad cap and then back and you can just see it there. On the car it's about halfway down the block and has a rad hose to it.
So I've just looked at my Manual CD and it talks about it being under the inlet manifold as you are saying.
However, I'm not sure if my Manual is talking about the single cam picture as all the diagrams seem to be for that engine.
I tried to look under my inlet manifold but it was not in the best light in my garage and to be honest I had to get on with what I needed to do.
So I'm a little unsure where it is still on the twin cam engine.
Can anyone else help with the location of the thermostat on a twin cam engine???
28 Nov 2011 07:58 #26775 by Halford
This is from the SN413 manual
which engine is this then, is this the DOHC ? :unsure:
Attachment engine-01.jpg553391.jpeg not found
Attachment thermostat-1.jpg not found
Time to create page: 0.160 seconds
