Dash showing engine temp is realy hot! NOW SOLVED!
- Nobby22
20 Nov 2011 18:13 #26191
by Nobby22
It would indeed! Also where abouts is the thermostat? I could probably find it eventualy but it would be good to be certain. Iam going to get a new one tommorow. They dont seem that expensive so i better get one just in case it is shot and i carnt put it back together :laugh: .
Nobby
Replied by Nobby22 on topic Re: Dash showing engine temp is realy hot!
teafortwo0789 wrote: I don't think you're thick, well no thicker than I am. I was also wondering how to cable tie the fan up. A quick photo would help.
Nobby
- Keefe
20 Nov 2011 18:25 #26193
by Keefe
Replied by Keefe on topic Re: Dash showing engine temp is realy hot!
Thermostat, on the M13A motor.
Off side under the inlet manifold towards the front.
If that helps?
If that helps?
- Nobby22
20 Nov 2011 18:37 #26196
by Nobby22
Iam sure it will, thanks. I did have a quick look today and i thought i would be some where around there. Is it on the end of the pipe comming out the bottom of the radiator, off side?
I could be completely wrong :blush:
Nobby
Keefe wrote: Thermostat, on the M13A motor.
If that helps?
Nobby
- Keefe
20 Nov 2011 20:39 - 20 Nov 2011 20:50 #26212
by Keefe
Yes, that pipe leads up to it.
You have a PM....
You have a PM....
Last edit: 20 Nov 2011 20:50 by Keefe.
- Nobby22
26 Nov 2011 09:25 #26612
by Nobby22
Well..... I have had a look and the bloody thing is right under the intake manifold
. If it was a weekend toy i would probably have a go at takeing it all apart but i carnt risk me not being able to put it back together
. Theres no way i can get to it any other way. Looks like another trip to the garage.... again
Nobby
Nobby
26 Nov 2011 12:37 #26623
by kirkynut
Replied by kirkynut on topic Re: Dash showing engine temp is realy hot!
Do you have the single or twin cam engine mate?
Time to create page: 0.433 seconds
