back door getting stiff to open and close
- Thank you received: 673
08 Jun 2023 22:12 #249469
back door getting stiff to open and close was created by DrRobin
So I have noticed over the last few weeks the back door on my Gen is starting to get stiff to open and close. It felt like hinges, so I gave them a spray with some lubricant and it seemed to get a little better, but now it’s worse than ever.
i am now thinking that it is the the damper strut, is this how they go, massive amounts of damping/stiffness?
i might try disconnecting the damper and see if the rear door moves correctly. Or, do the hinges start to cease up?
Ta
Robin
Ta
Robin
09 Jun 2023 00:27 #249470
by fordem
Replied by fordem on topic back door getting stiff to open and close
In my experience the struts gradually lose their ability to hold the door so it gets easier to move not stiffer.
09 Jun 2023 07:15 #249474
by Abudougal
Replied by Abudougal on topic back door getting stiff to open and close
MInes the same and again heaps of wd40 didn't help.
09 Jun 2023 10:05 #249479
by facade
Replied by facade on topic back door getting stiff to open and close
It's the hinges.
You need to get oil into them, not WD40.
GT85 will help as it has a teenie amount of teflon in it.
You could keep applying a small amount of diesel, it penetrates and lubricates.
I used to keep squirting a little oil into that notch in the hinge and then open & close the door about a thousand times- you don't have to let it latch.
The bonnet hinges seize too, you need to get the deck under the wipers up to lubricate them, I took mine off one at a time to do a good job. (And lubricated the wiper mechanism whilst the deck was off.)
09 Jun 2023 20:18 #249486
by driver9
Replied by driver9 on topic back door getting stiff to open and close
Agree with others that a failing gas strut tends to go weak not stiff. Tygris R223 white lithium grease with PTFE lubricant spray is good for door hinges because its waterproof. I've used it on the Defender hinges for a number of years with good results.
09 Jun 2023 21:07 #249487
by Abudougal
Thanks guys, I think I have some lithium spray somewhere, I'll get to work with it.
Time to create page: 0.248 seconds
