Cold weather preparedness.
- Roger Fairclough
- Thank you received: 225
19 Jan 2023 15:20 #247017
by Roger Fairclough
Replied by Roger Fairclough on topic Cold weather preparedness.
Hi Doc.
Its possible that the position that you park the car can influence the degree of frost build up. Tonka is parked next to a tall hedge and that protects her to an extent. Also wind direction can have a strong effect.
Roger
Roger
- Thank you received: 663
19 Jan 2023 16:46 #247019
Replied by DrRobin on topic Cold weather preparedness.
Thanks Roger,
It's parked out in the street and when I defrost it in a morning the frost is pretty uniform over the front windscreen and bonnet, so I reckon, it's still the exhaust location and the fact that the washer tube is shorter to the passenger side.
I would prefer it if the drivers side jets defrosted first, but then I guess in left hand drive cars it does. Hopefully re-routing the tube will help, otherwise it is back to pulling over and using the hand spray bottle.
Robin
Robin
- Roger Fairclough
19 Jan 2023 16:55 #247021
by Roger Fairclough
Thanks Doc.
I find that the defroster on the Gen.4 is fast and powerful. If I start Tonka and then start scrapping at the drivers side, the frost on the passenger side w/screen will be mushy by the time I get to it. Also the washer jets are clear by the time I drive off but I put that down to the 50-50 mix in the washer bottle.
Roger
Roger
22 Jan 2023 19:46 #247098
by Grizzlie
Replied by Grizzlie on topic Cold weather preparedness.
I find threads like these start to build up with unnecessary gear. Similar to a person's EDC where they start carrying a bottle opener, a lighter [even though one doesn't smoke], a keychain knife, a pocket knife, a boxcutter, a pocket prybar, two pairs of sunglasses, miniflashlight, fullsize flashlight, a kubotan pen, and a multitool...omg.
My daily driver's (DD} winter EDC is:
-Shovel
-Blanket
-Thermal underwear (top and bottom)
-Winter work gloves
These get taken out come summer.
I don't see the point of granola bars or water. Extra phone batteries will die quickly unless on person or charged constantly. Water freezes unless kept near a heater. Granola bars...fine, they have a long shelf life.
Mind you, this is an EDC for a Daily Driver for a normal day. Week[end] warrior mode sees granola bars and bottles of water and themoses with hot tea. Definitely throw in some recovery boards, kinetic ropes., etc etc. A backup charged phone, sure.
A healthy car battery is good to have. But I've gone through -25 to -30C winters here in Eastern Europe with a suboptimal battery on a tender overnight. Nozzles frozen? Occasionally. But I find those days are so cold that the windshields need a cleaning much less often...because it's so cold that road spray is less of a problem. [be sure to fill up on winter washer fluid].
I do remember a winter many moons ago that was -36C for a few days...my diesel VW took a day or two off way back then.
-Shovel
-Blanket
-Winter work gloves
28 Jan 2023 19:27 #247240
I tried wrapping a flexible washer tube round the radiator pipe and it seems to work fine so bought a small length of copper pipe and wrapped this round the pipe, seems to work great, now all we need is some -5C temperature again.
Robin
winding the copper tube on a former (axle stand)
In place and connected to the flexible pipe.
Robin
Time to create page: 0.281 seconds
