Cold weather preparedness.
16 Dec 2022 08:05 #246404
by Scimike
Replied by Scimike on topic Cold weather preparedness.
I can't really see how heating a small proportion of the screen wash tube via the engine helps. You still need additive to prevent freezing overnight and only a small section is actually heated, so you spray cold / hot / then cold again as you pump the tube out, so not even a hot wash (which can help).
I Had a VW with heated spray nozzles, I guess the plan was to help with it's frozen extremities on very cold nights as nozzles can "air freeze" even with additives.
Could be wrong with my reasoning, just thinking about it as I actually like the solution/ heat exchanger used.
- Thank you received: 627
16 Dec 2022 10:37 #246405
Replied by DrRobin on topic Cold weather preparedness.
In my experience it is the nozzle that needs heating, not the liquid, as Mike says it can freeze even with additives.
Pity they don't make them for the Jimny, unless you can get them for another model that are the same size?
- Thank you received: 1936
16 Dec 2022 11:49 #246406
Replied by Lambert on topic Cold weather preparedness.
There are generic ones on eBay that you wire up. Don't know how hot they get or how much cutting would be involved. Also don't underestimate the level of heat soaking that the washer bottle will get living on the hot side of the engine bay given how hot it gets under the bonnet on a relatively short run in a Jimny.
16 Dec 2022 13:32 #246407
by RainerK
Replied by RainerK on topic Cold weather preparedness.
The nozzle freezes, because there the additives (usually alcohol) at the end of the nozzle evaporate and the remaining water freezes. So heated nozzles would be great.
The following user(s) said Thank You: DrRobin
- Roger Fairclough
- Thank you received: 217
16 Dec 2022 13:40 #246408
by Roger Fairclough
Replied by Roger Fairclough on topic Cold weather preparedness.
Ford fit/fitted heater nozzles to some models. They were permanently wired through the ignition circuit. Last night was -7 deg. C and my nozzles were frozen. This is not the washer fluid but frost on the outside of the nozzle.
I wont to reiterate my previous comments. My experience goes back many years to my rallying days when we tried wrapping polythene tubing round a heater hose but found it only marginally effective. I have experimented with various systems including a 16ft double coil of copper brake pipe that ultimately proved OTT until I found that my present system proved effective and simple. The fact that it resembled the system used by Saab is purely coincidental but pleasing that they also consider that it is suitable for Swedish winter conditions.
So there you have it, I find the system works for me, know it's up to you.
Roger
Roger
16 Dec 2022 15:14 - 16 Dec 2022 15:15 #246410
by Motacilla
Replied by Motacilla on topic Cold weather preparedness.
Roger, that looks to be a really well-made assembly, nice work. If you decide to put them "in production," put me at the top of the list. (Seriously.)
I think if people did the maths on the fluid flow of a windscreen washer pump vs the output of an electric heating element, they would quickly understand why drawing the heat from the engine is a far superior solution to trying to heat the fluid electrically. (Heated nozzle tips being another matter, solving a different problem requiring less heat energy.)
Really impressed with the ingenuity, and particularly with the level of finish of the part in the photo. Thanks again for posting.
Last edit: 16 Dec 2022 15:15 by Motacilla.
Time to create page: 0.204 seconds
