Garage near Aylesbury (Buckinghamshire) for front axle seals/bearings
10 Aug 2022 18:20 #244492 by CJ Davies
They seem to mainly work on Lamborghinis & TVRs - there was even a Huracan on a lift when I went in!
Good to hear about the ball though, that's one less expense/worry.
25 Aug 2022 08:21 #244734 by CJ Davies
Well that looks a bit better! Turns out it was the lower kingpin bearing in the end.
31 Aug 2022 07:30 #244803 by Jezza
I have exactly the same problem, heard a slight rattle from the front end, looked underneath and grease all over the swivel joint, even got splattering on inside tyre wall. Same on both sides. Can someone confirm that I need to order "kingpin bearings and swivel seal" £48 a side from bigjimny store. Thanks
31 Aug 2022 08:34 #244804 by Lambert
That's correct.
31 Aug 2022 10:14 #244807 by Jezza
30 Sep 2022 05:50 #245222 by Jezza
got my bearings and seals from bigjimny shop and my local garage changed them both. They too were concerned about the balls being pitted and potentially ripping the seals. Martin says this is all quite normal, so should i be concerned ?
