Garage near Aylesbury (Buckinghamshire) for front axle seals/bearings
  • CJ Davies
25 Jul 2022 10:34 #244214 by CJ Davies
I’ve just driven 450+ miles south from Dundee to Aylesbury, moving house for a new job. A few days before the move, I discovered what I now understand is a common issue - a lovely mix of diff oil & CV grease leaking from the passenger side front wheel swivel. I couldn’t get it seen to in time before the move, but the car was still driving fine & I figured the only danger would be if the front diff ram completely dry. I had it topped up at a local garage (took 300ml) & asked them not to over-tighten the fill plug, so I could remove it & check the level myself halfway down & once I arrived. As far as I can tell, it’s still essentially full & there’s only a tiny drip on the driveway this morning.
I’m now trying to find a garage to fix the problem, but I’m not having much luck. I called a local Land Rover specialist (John Dennis) but they said they would struggle to get the parts & they wouldn’t fit parts that I provide myself.
Does anybody have any recommendations? Even if there is a local member who’d be willing to do the work, I’d pay parts & labour. My new job starts next week, so a potentially temperamental car is the last thing I need!
Photo taken before the move.
25 Jul 2022 11:40 #244215 by Lambert
Too far south from me I'm afraid. There's a very good how to guide in the information section above and a novice should probably expect half a day per side with basic hand tools.
  • CJ Davies
25 Jul 2022 11:53 - 25 Jul 2022 11:55 #244217 by CJ Davies
I toyed with the idea of doing it myself, but I'm actively trying not to acquire more tools right now. I actually got rid of a bunch of tools when I moved - things which I'd bought for one specific job, used literally once or twice & then just ended up storing for years. I've moved to a smaller flat, so space is at a premium.
I have a decent socket set, but assuming I could get away with using the emergency scissor jack from the boot I'd still need to buy axle stands, circlip pliers, the torx socket for the hub bolts, a ball joint splitter & a 1" imperial socket. Pretty much all of that I'd never use again, especially as I actually have a new car on factory order that will hopefully arrive before the end of the year.
Edit - I'd need a torque wrench as well, for putting the wheel back on.
Last edit: 25 Jul 2022 11:55 by CJ Davies.
26 Jul 2022 10:38 #244230 by Busta
I can't help with getting it fixed, but a FYI: The front diff is completely staionary when driving in 2wd, so requires no lubrication. Unless you are regularly using 4wd for long periods of time it's best to leave the oil level low until you get the leak sorted.
26 Jul 2022 10:45 #244232 by Busta
Also you don't need a lot of that stuff to do the job. You can leave the vacuum hub on and pull the driveshaft out with the whole hub assembly, so no need for the torx bit or circlip pliers. It's a little bit more awkward than ful dissasembly but it's perfectly possible. Ball joints are easily split with a hammer blow to the side of the bit they go through. The 1" socket thing is also a distraction as it's the outside diameter of the socket that matter, and that varies from brand to brand. There's a very good chance that you will have one that fits in a metric set. Or you can knock the inner races out with a punch/screwdriver/chisel etc. There's always a way!
  • CJ Davies
26 Jul 2022 10:55 #244233 by CJ Davies
My understanding is that the front diff & the front half shafts are always spinning with engine power, as 4WD is engaged at the vacuum hubs & not further back in the driveline?
This is the reason why you can't tow a Jimny with the front wheels elevated but the rear wheels on the ground, no? Because turning the rear wheels turns the front half shafts & you don't want those spinning at road speed when the wheels aren't turning, as heat builds up in the hubs?
