BigJimnyMeet 2024
Clutch pedal
11 May 2021 10:45 #234963
by Stefan
Replied by Stefan on topic Clutch pedal
New to driving a Jimny, and a petrol vehicle for that matter. But not new to manual. Been driving manual diesels most of the time before I got the Jimny.
11 May 2021 10:48 #234964
by Stefan
Guess it's time then. Assuming it has never been changed before I got it by the other two owners.
11 May 2021 10:53 #234965
by Stefan
Didn't know that.
Must I revv up to 4000 in first gear?
I don't know if it is adjusted correctly. I'll just have to send it to Suzuki either way.
11 May 2021 10:56 #234966
by Stefan
Alright, sounds promising. I did short shift at first but after I had exhaust leaks to repair and did some googling I found short shifting is a bit bad for the cats, my father told me 3000 is best for petrol engines.
- Roger Fairclough
- Thank you received: 194
11 May 2021 11:34 #234968
by Roger Fairclough
Replied by Roger Fairclough on topic Clutch pedal
I suggested 4,000 rpm as that should be at about max. torque but as others have said, it sounds as if a new clutch is the order of the day.
Roger
Roger
- Thank you received: 1761
11 May 2021 11:53 #234970
Replied by Lambert on topic Clutch pedal
The vvt doesn't come on till around 4000 rpm and is good for another 2000 rpm after that. These are small engines and need many rpm to make power and torque. Don't be afraid of the top half of the rev range.
11 May 2021 12:09 - 11 May 2021 12:10 #234971
by Stefan
Thank you for the input. I'll need to make absolute sure about the case before stating it to my father (owner). He will just say it can't be, so I'll need solid proof, and he doesn't like what people suggest on the internet.
Last edit: 11 May 2021 12:10 by Stefan.
11 May 2021 12:12 - 11 May 2021 12:12 #234972
by Stefan
This Jimny hardly accelerates above 3000 rpm except in 5th gear I can get to 100km/h at about 3200 rpm.
Last edit: 11 May 2021 12:12 by Stefan.
11 May 2021 17:33 - 11 May 2021 17:33 #234981
Then it needs an Italian tune up also known as a good long thrashing up a motorway. When I first got my current Jimny off my parents it too didn't like the top of the rev range, it got much better for being used properly. A Jimny is not a big lumbering diesel it has more in common with a sports bike.
Last edit: 11 May 2021 17:33 by Lambert.
12 May 2021 17:19 #235003
The M series engine when properly tuned doesn't start to do anything interesting before 3000 rpm. If its VVT then that kicks in at about 4000 meaning they are clearly intended to be up in the revs before any action. Theres plenty of M series engines flying about in swifts with a 8000+ rev limiter set. Ive set mine at 6600, which is very conservative for what it can do.
Italian tune up time without telling the owner
Replied by Riccy on topic Clutch pedal
That proves what Lambert is saying. They need revs and lots of them to get the best from the engine.This Jimny hardly accelerates above 3000 rpm except in 5th gear I can get to 100km/h at about 3200 rpm.
13 May 2021 17:24 #235015
by Stefan
Need to check what type mine is, think it's an M type. What's with the 16 valves in such a small engine too?
I'll try the Italian tune up, just don't have a lot of open roads out here in the country.
Time to create page: 0.174 seconds
