Jimny 3 Boot Storage - inspiration please!
- AngusChap
01 Mar 2020 14:42 #219243
by AngusChap
Jimny 3 Boot Storage - inspiration please! was created by AngusChap
I’m using our Jimny as a bit of a quad / gator / mule substitute on our shoot and I’m looking for inspiration for maximising l boot storage.
I’ve currently got a Jimny boot liner over the top of the back seats and whilst it’s handy, feed bags, tool boxes and dogs tend to slide about a bit!
My plan is to build a custom storage set up out of plywood with high sides so I can pack things in a bit better and know they’re secure. I’ve had a look on the forum and seen bits and bobs but no specific thread about it so I thought I would see if anyone had done anything similar so I can pinch good ideas!
I’m happy to take out the back seats or leave them in, doesn’t make much odds either way. Thoughts and photos much appreciated!
- gusthegorilla
01 Mar 2020 17:15 #219250
by gusthegorilla
Replied by gusthegorilla on topic Jimny 3 Boot Storage - inspiration please!
01 Mar 2020 19:21 #219257
by Scimike
Replied by Scimike on topic Jimny 3 Boot Storage - inspiration please!
I have also removed the rear seats and have similar to Chris above.
Having made the change I believe that if you have no need for the rear seats take them out, they do nothing but occupy valuable space, even when folded down in the G3.
With them removed you can go for a single load area or a multi layer area, keeping the stay in car bits hidden. Anything is possible and a bit of carpet or covering and it looks professional.
Mike
Mike
- AngusChap
01 Mar 2020 21:11 - 01 Mar 2020 21:12 #219259
by AngusChap
Replied by AngusChap on topic Jimny 3 Boot Storage - inspiration please!
Looks like the back seats are coming out then!
I’m looking to make more of a partitioned container than just a flat loading area but it’s definitely good to see how it looks without the back seats in. Definitely opens it up a fair bit more.
Will have a play once the back seats are out and share some photos of the eventual set up
Last edit: 01 Mar 2020 21:12 by AngusChap.
- Thank you received: 1983
02 Mar 2020 05:40 #219267
Replied by Lambert on topic Jimny 3 Boot Storage - inspiration please!
Keep an eye on what you make your deck out of. Mine is in 6mm plywood with sides and a bulkhead and it struggles to weigh 10kg which is good as it means more freight can go in the back without overloading the gvm. It's still plenty strong as the spans between support are small and the sides prevent too much flex and warp. I could have done it in 12 or 15mm but it would have been massively heavy and reduced the cargo capacity.
- gusthegorilla
02 Mar 2020 08:08 #219270
by gusthegorilla
Lambert...if your Jimny were the size of an aircraft carrier, the difference in weight, and volume, might be relevant....
With the seats removed, the Jimmy's load space measures 100 x 118 mm max...
I built my very first one out of 6mm, and over time it warped and looked shabby....10mm exterior ply I found infinitely superior, and the difference in weight and volume is miniscule...
....just saying...!!!!
Time to create page: 0.247 seconds
