Clicky clicky no starty
- lesgrandepotato
- Elite Member
- Thank you received: 57
27 Jul 2023 18:48 #250020
by lesgrandepotato
Working on paint prep on the Sami… so she’s all apart again… getting closer but we have a new behaviour. Now she doesn’t want to run. Turn the key and we get a rapid fire click click then sometimes silence.
Quick Google suggested ignition switch. So I hunted around and found a new one from India that came with the car.
Quick fiddle and it’s in. And we get clicky clicky no start again… what’s going on then? I can trace it out with time but I could do with an instant answer if anyone knows where to look!
Clicky clicky no starty was created by lesgrandepotato
27 Jul 2023 19:44 #250021
Replied by jackonlyjack on topic Clicky clicky no starty
is battery down on power
do these have starter selenoid if yes have you tried shorting the terminals ignition on
stuck starter motor give it a rock in gear or tap it with hammer
The following user(s) said Thank You: lesgrandepotato
28 Jul 2023 01:05 #250024
by fordem
Replied by fordem on topic Clicky clicky no starty
The "rapid fire" click is usually a dead or discharged battery, there's enough juice to pull the starter solenoid in, but when the solenoid contacts close and the load of the starter hits it, the voltage drops and the solenoid drops out disconnecting the starter, without the load of the starter the battery recovers, the solenoid pulls in again, drops out again, and the cycle repeats.
It looks like it may have been lying unused for some time, charge the battery first and if that doesn't fix it, you'll most likely need to replace it.
There's a slim chance of it being loose or dirty battery connections so clean & tighten those also.
- lesgrandepotato
- Elite Member
28 Jul 2023 11:58 #250025
by lesgrandepotato
Replied by lesgrandepotato on topic Clicky clicky no starty
- lesgrandepotato
- Elite Member
30 Aug 2023 19:09 #250580
by lesgrandepotato
The mystery thickens! I’ve been chasing this issue about a while now. Sometimes it’s fine. Sometimes it clicks. Sometimes it just sends the whole car dead. No power anywhere.
Then after a period of time in seconds to mins she’ll just light up again….
So I’ve changed out the ignition switch to a new one. I’ve taken the starter out and bench tested it. All good.
I’ve tried tickling the starter in the car with power to the start connection. Nothing. No clicks, no pops. Not a sausage.
I think the starter or solenoid are the problem. But I don’t see why. I guess it could be the wrong unit? Are there different models? I guess the solenoid only works in some positions?
Any sage advice before I spring £70 on a new starter?
30 Aug 2023 19:57 #250582
by Finners
Replied by Finners on topic Clicky clicky no starty
Sounds more like a bad connection , I’d clean and wire brush /emery cloth the battery terminals and the leads to the earth point and the starter ,
Time to create page: 0.255 seconds
