Head light mounts
- lesgrandepotato
- Elite Member
- Thank you received: 57
25 Jun 2023 17:34 #249629
by lesgrandepotato
Head light mounts was created by lesgrandepotato
Ok. I’m confused. I’ve got some new indian beauty rings. Some new wings from Taiwan. Some chunky plastic circles that may or may not be part of the solution.
I’ve heard tell of asymmetric headlamp rings and evenly spaced ones.
I cannot figure out how any of the bits may or may not fit together. Does anyone have a diagram / photo?
- lesgrandepotato
- Elite Member
25 Jun 2023 17:48 #249630
by lesgrandepotato
Replied by lesgrandepotato on topic Head light mounts
I’m minded to buy a set of these.
Lights
Thoughts? Might need spacing for depth but at least I’d have all the bits.
Lights
25 Jun 2023 19:18 #249631
Replied by mlines on topic Head light mounts
So our SJ413 (1986) came with 3 point fixings spaced like a letter Y on its side, our new cheap samurai came with the point fixings equally spaced, I believe that the Samurai ones have an additional bowl that fixes to the points whilst in the original SJ413 the headlamps fit direct to the mounting points
The following user(s) said Thank You: lesgrandepotato
- lesgrandepotato
- Elite Member
25 Jun 2023 19:45 #249632
by lesgrandepotato
Thanks Martin, I’ve ordered a set of standard bowls for a mini etc. I’ll fabricate some mounts. At least I’ll know the bits are meant to be together even if not on this car.
Once I have that I can set the grill and then adjust the wings to fit…
27 Jun 2023 11:01 #249642
Replied by yakuza on topic Head light mounts
I am a bit concerned for the cooling in the bowls if hot halogene bulbs are used..
I tried to put Golf II headlights on my SJ but even though they where 7" they did not fit the Suzuki rings. My '84 got the uneven Y-type.
Time to create page: 0.166 seconds
