Re:Roll bar options
- lesgrandepotato
- Elite Member
- Thank you received: 57
05 May 2023 14:00 #248967
by lesgrandepotato
Roll bar options was created by lesgrandepotato
I’m fancying a roll bar for our little plaything. Nothing too heavy duty just a bit more protection than the stock tin roll hoop that doesn’t look that robust…
Anyone have any leads? Or recommendations?
05 May 2023 14:27 #248968
by jlines
1986 SJ413JX (Lil Red)
2018 JB43 SZ4
2019 JB74 SZ5 (Gerald)
2023 JB74 LCV
Replied by jlines on topic Roll bar options
Is this for an SJ or Jimny?
2018 JB43 SZ4
2023 JB74 LCV
- lesgrandepotato
- Elite Member
05 May 2023 14:45 #248969
by lesgrandepotato
Replied by lesgrandepotato on topic Roll bar options
It’s an SJ samurai 1992 convertible
05 May 2023 15:14 - 05 May 2023 15:14 #248971
by jlines
2018 JB43 SZ4
2023 JB74 LCV
Ok it would have to be an aftermarket option as suzuki didn't make anything more than the standard rollbar.
Masterforest make one although looking at the pics this may not work well if you have carpets or mats on the floor.
www.masterforest-boutique.com/en/bumpers...uki-samurai-4wd.html
Our old SJ had a baby saver style roll cage built by Rhinoray in the UK although this didn't work with the soft top canopy support hoop.
2018 JB43 SZ4
2023 JB74 LCV
Last edit: 05 May 2023 15:14 by jlines.
06 May 2023 08:13 - 06 May 2023 08:16 #248978
Replied by mlines on topic Re:Roll bar options
When you say "tin roll hoop" do you mean the "Targa bar" that is part of the actual construction of the SJ or the optional Suzuki Roll Hoop?
If you are going for authenticity then the optional suzuki hoop would be your only choice. As James is doing a "factory" restoration he has gone for the Suzuki hoop of course. However the hoop is not particularly strong and back in the day was not compliant with AWDC regs for a lot of their competitions. The rear brackets on it are for "support" and not strength.
If you need to have it as a real functioning roll bar, I would go for a look-a-alike standard hoop but made of certified tube and with proper rear angle bars down to the back of the car and big spreader plates to spread the load and bolted through to the body stiffening members underneath
I have attached pictures of the Suzuki roll hoop
Sent from my moto g42 using Tapatalk
Last edit: 06 May 2023 08:16 by mlines.
- lesgrandepotato
- Elite Member
06 May 2023 09:06 #248979
by lesgrandepotato
Replied by lesgrandepotato on topic Re:Roll bar options
Aha, terminology issues! I have the targa bar. I suspect a factory roll hoop would be fine for what we are up to (tyro / rtv) it’s just in case of the worst happening.
Are the factory bars readily available? A part number always helps when chasing the rarer bits!
Time to create page: 0.172 seconds
