Help please
  • talby2491
12 Mar 2017 12:36 #179114 by talby2491
Help please was created by talby2491
My dad has a 2004 suzuki vitara 2.0td over the last few days it's struggled starting now it now won't start at all I checked fuel is getting to injectors all fine problem is there is a substance that looks like milk in lemonade is this faulty fuel I noticed it when I cracked open the fuel pipe to the injector when car starts it idles uneven and throws out black white smoke head gasket is good and no signs of water in oil or oil in water any help greatly appreciated tia
12 Mar 2017 22:31 #179140 by Busta
Replied by Busta on topic Help please
Any contamination in the fuel will cause problems. First port of call would be changing the fuel filter. If that is gunked up too you will need to drain the fuel tank and start again with fresh fuel.
  • ZookFastback
13 Mar 2017 02:50 #179148 by ZookFastback
Replied by ZookFastback on topic Help please
If it is water in fuel, a temporary fix until you clean the tank and lines out is to put 500ml (about a pint I think in the olde-fashioned measurements) of Methylated spirits into the tank. This will make the water soluble in petrol and let it go through to the combustion process and out the back as volumous white cloud.
13 Mar 2017 18:50 #179170 by Riccy
Replied by Riccy on topic Help please
ZookFastback wrote: If it is water in fuel, a temporary fix until you clean the tank and lines out is to put 500ml (about a pint I think in the olde-fashioned measurements) of Methylated spirits into the tank. This will make the water soluble in petrol and let it go through to the combustion process and out the back as volumous white cloud.
its a diesel, probs best not to try that ;-)
Time to create page: 0.197 seconds
