4U general purpose tow bar help please
- Invicta
15 Sep 2015 21:40 #152035
by Invicta
4U general purpose tow bar help please was created by Invicta
Occasionally I will be using my recently bought 2000 1.6 Vitara 4U to tow a LOGIC flail mower around a paddock and on the road (from one site to another).
Ideally I'm after one that I can remove the swan neck from when it's not in use.
Having had a look around the various ones on the web/eBay I'm confused as to which is compatible.
Can anyone help please?
Thanks for looking,
Bern
Thanks for looking,
Bern
16 Sep 2015 15:47 #152065
by Rhinoman
Replied by Rhinoman on topic 4U general purpose tow bar help please
The SWB petrol models all use the same towbar. The genuine Suzuki aftermarket towbar had two additional long bolts that went up through the chassis and gave a much stronger mounting, the Suzuki electrics kit for it was also plug in so no butchery with Scotch-Loks.
17 Sep 2015 20:15 - 17 Sep 2015 20:20 #152144
by Rhinoman
The Suzuki towbar was made by Bosal (016-172), I'm sure that it could be sourced cheaper. The tow rating on the towbars without the extra bolts is much lower.
Last edit: 17 Sep 2015 20:20 by Rhinoman.
17 Sep 2015 20:21 #152145
by Rhinoman
The following user(s) said Thank You: Invicta
- Thank you received: 923
17 Sep 2015 20:59 #152147
Replied by X8GGY on topic 4U general purpose tow bar help please
I did the same (as Suzuki) with
my rear recovery points
, mounted the same kind of way...
- Invicta
18 Sep 2015 17:50 #152198
by Invicta
Replied by Invicta on topic 4U general purpose tow bar help please
We are just back from first holiday this year (a couple of days near Southwold on the east coast).
"The Suzuki towbar was made by Bosal (016-172), I'm sure that it could be sourced cheaper. The tow rating on the towbars without the extra bolts is much lower."
This was exactly the sort of guidance I was after.
I'll have a search around for a Bosal unit and those extra bolts with the Suzuki plug in electrics kit.
The fitting instructions are also much appreciated.
If anyone comes across all or some of the above then please let me know.
Thank you for the replies so far,
Bern
Bern
Time to create page: 0.197 seconds
