Jimny from Greece
  • Delvederis
  • Visitor
  • Visitor
25 Aug 2013 13:12 - 25 Aug 2013 13:14 #80989 by Delvederis
Replied by Delvederis on topic Jimny from Greece
Some update, changed the 31/10.5/15 with 215/85/16.
The new tires are 2cm taller than the 31's, the car goes way much better.
Also changed the 4.16 t-cade gears with 4.9. The high range is almost the same, but in 4L things get hard :evil:
And finaly i got a 2000cc 4cylinder Grand Vitara engine to fit in the next months.
Last edit: 25 Aug 2013 13:14 by Delvederis.
  • Stan
  • Visitor
  • Visitor
26 Aug 2013 14:25 #81060 by Stan
Replied by Stan on topic Jimny from Greece
panosd wrote: Hello, i took them from a friend of mine who put hilux axles in his car.
They are from subaru. In pics you can see the part number.
The part numbers are hard to read, can you post the part numbers here please?
26 Aug 2013 14:29 - 26 Aug 2013 14:31 #81062 by MigCooper
Replied by MigCooper on topic Jimny from Greece
Hi
How much better will this cv's be comparing with the std jimny ones?
they look to be a great option anyway
What was the donor Subaru model?
Thanks
Snorkel and plenty of rust to be treated :)
Last edit: 26 Aug 2013 14:31 by MigCooper.
05 Sep 2013 15:52 #82269 by safari
Replied by safari on topic Jimny from Greece
hi very interested in what u did can u explain what kind of cv u used and what car pls
if u worry u die if u dont worry u still die so why worry
  • GuardianAngel
  • Visitor
  • Visitor
05 Sep 2013 16:11 #82270 by GuardianAngel
Replied by GuardianAngel on topic Jimny from Greece
panosd wrote: Today i found the pics from my front arb instalation with the HD axleshafts and cv joint.
On pics the clean are the hd and those with the grease are the stock one.
As you can see, they are a straight replacement and they can handle until 33'' tires with front arb locked.
Excuse my ignorance but how are the Scooby drives shafts better? Thicker shafts, better quality materials? I imagine with the extra horses they would need to be, but...
Also part numbers would be great ;-)
  • jonesyba420
  • Visitor
  • Visitor
13 Feb 2014 17:34 #104400 by jonesyba420
Replied by jonesyba420 on topic Jimny from Greece
You cant read the part numbers in your picture.
Which subaru were they from? Was it an imprezza?did you have to replace anything else ie diff wise or are they the same splines?which jimnys are they compatible with as im sure some front diffs vary when it comes to the amount of splines?
  • GuardianAngel
  • Visitor
  • Visitor
13 Feb 2014 18:31 #104405 by GuardianAngel
Replied by GuardianAngel on topic Re:Jimny from Greece
Yes part number would very useful ;-)
  • Delvederis
  • Visitor
  • Visitor
28 Feb 2014 15:56 - 28 Feb 2014 16:00 #106493 by Delvederis
Sorry but the shafts and cv's are already installed and i dont have any other pics or data for the parts :(
Last edit: 28 Feb 2014 16:00 by Delvederis.
  • Delvederis
  • Visitor
  • Visitor
25 Apr 2015 16:16 #143160 by Delvederis
After a raid race where i was and with a set of 205/80/16 cross tyres i blow up my front hd axle shaft and cv.
So as it has been in the back of my mind for a long time, the moment has come.
I got a set of Nissan Patrol MK/MQ axles with arb diff lockers already installed, and also with rear disc breaks.
Also i got a set of 33/10.5/15 BF KM2 which will go on a set of 15x8 procomp alloy wheels ( had them already).
For start i will use the same suspension that has already been installed, and later i will go for 3link front and 4link rear.
A hydraulic hand break will be installed to come up with the rear disc breaks.
And a teaser pic of how the jimny will be with the 33's
  • TomDK
  • Visitor
  • Visitor
25 Apr 2015 16:41 #143162 by TomDK
Replied by TomDK on topic Jimny from Greece
Sorry. But I really can't see the point in installing such wide and heavy axles on a Jimny, or the 33" tyres for that matter.
The Jimnys force is it small size and low weight.
Putting on such heavy axles does nothing good for anything. And it's unspung mass.
The patrol axles are definitely interesting as they're very strong and pretty cheap. Just not on a Jimny if you ask me.
Actually a bit funny that Patrol Y60 and Y61 axles have been a popular mod for 4x4's here in Denmark for many years. But it's only recently that the British 4x4 people have found out about that :)
  • Delvederis
  • Visitor
  • Visitor
26 Apr 2015 13:43 #143193 by Delvederis
The choise of the patrol axles was made for :
1) because there was already arb airlockers installed in both axles,
2) the price was very good,
3) even in stock (as mine) they are stronger that the Toyota land cruiser LJ/ BJ 70 and Mercedes G
the patrol ones can come up to 37'' without upgrades than the other that can't go more than 235/85/16 and soft
tyre pattern ex. not caiman or cross
4) patrol axles are just about 6cm wider than toyota and about the same with G, so no wheel spacers needed.
Also better stabillity provited by the wider axle.
5) patrol are just about 12kg heavier from the toyota and almost the same with G
6) more weight in the axles will help privent roll overs, because of the low center gravity.
So the positives where more than the negatives.
Also the tracks we have here are rough enough to challenge the endurance of the axles.
In Greece we use patrol Y61 and MK/MQ axles for almost 10 years now in challenge trucks,
as far as i know because thats the time i also being involved.
  • TomDK
  • Visitor
  • Visitor
26 Apr 2015 16:31 #143198 by TomDK
That's all very good.
And I understand why you'd want to go with the ARB lockers.
But instead of comparing with Toyota axles you need to compare them with Jimny axles.
It's common knowledge to most people that use their 4x4 for competition that Y61 are some of the strongest OEM axles available.
Just to be clear. On must heavier vehicles I'd put Y61 axles on myself. But not on a small 4x4 like a Jimny. There are far better options available.
Time to create page: 0.192 seconds
