Re:DrRobin's Northumberland Jimny
- Thank you received: 567
06 Sep 2024 08:47 #257457
Replied by DrRobin on topic Re:DrRobin's Northumberland Jimny
The quarry is not in use on a Sunday and the club (North East 4x4 Club) has long standing permission to use it for 4x4 play days and trials. They are more about trials and careful off road driving rather than hills too big to get up. It’s also only open to road legal vehicles which keeps it sensible.
The Jimny’s weak point is ground clearance, especially to a LR90 which has a similar wheelbase, although a Jimny has less over hang and is narrower than a 90. The 90s get one shunt on each stage, the Jimny doesn’t so it helps to walk the course and not go first.
A Jimny excels in the tight turns, just because it’s short and narrow, the garden canes are set at 7ft apart and a Grenadier can only just fit through.
Going over humps the long vehicles like a LR110 and Grenadier bottom out about the same as a Jimny, even though they have much higher ground clearance, their much longer wheelbase works against them.
Rutted tracks are a threat to a Jimny, unless you can straddle them.
The trial this Sunday is back at the quarry, I will let you know how I get on.
Robin
Robin
12 Sep 2024 21:58 #257517
Another trial day down at the quarry with the North East 4x4 Club. This course was not particularly Jimny friendly, it suited vehicles with much more ground clearance, but I gave it a try anyway.
Robikn
Robikn
13 Sep 2024 15:10 #257524
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic Re:DrRobin's Northumberland Jimny
Looks fun!
02 Oct 2024 13:10 - 02 Oct 2024 13:14 #257771
I fitted radius arm guards today, had them for about 3 weeks, but what with a holiday and the wet weather, this was the first chance.
I also have front and rear diff guards as well as a trasnfer case guard to fit, but they will have to wait unit I fit the Des Sol breather kit.
Robin
Robin
Last edit: 02 Oct 2024 13:14 by DrRobin.
11 Oct 2024 20:15 #257851
I fitted my Des Sol breather kit this morning. Although it went well I only got the front diff done, it took some time to route the breather pipe down the engine bay, the pipe kept twisting into the wrong place.
A tip, soak the pipe in hot water and hang with a weight, makes the pipe soft and easier to thread through.
The old valve removed, came off easy
The Des Sol breather adapter and pipe fitted
The breather box and filter
Whilst I had the front of the car jacked I fitted a front diff protector as I have a trial on Sunday and a trek the following weekend
I decided to spray it red so it will be easier to spot when I have scraped it and of course paint something red and it adds 50% to the strength.
Robin
Robin
14 Oct 2024 16:22 #257873
I entered another trial on Sunday and had more mixed results. The surface was a mixture of soil, some sand and recycled materials, which easily clogged the treads on my Worm Drives, but the course went over some short sharp rises, two of which I failed to get over and a couple of deep rutted parts that I also failed to clear, despite a very good go. At least I wasn't the only one, a few Landys failed as well.
The bright red front diff protector is no long bright red, but at least it's done it's job and apart from a couple of new scrapes underneath nothing major was broken.
I did get a loud clicking sound when using a fair few revs to get out of a muddy bit, I think it was one of the vacuum hubs which hadn't engaged correctly, although after toggling 4WD it seemed fine.
Video and photos to follow.
Robin
Robin
Time to create page: 0.347 seconds
