Re:DrRobin's Northumberland Jimny
05 Nov 2024 21:51 #258198 by jlines
Probably best to have a bridle or strap already attached if it's likely you will get stuck. Although securing high up on a standard car may be difficult as I've seen plenty come off and end up getting wrapped around the wheels.
  • DrRobin
  • Platinum Member
  • Platinum Member
  • Newbie in Northumberland
06 Nov 2024 10:10 #258201 by DrRobin
Thanks James, I thought about doing just that and tie the bridle up on the front bumper, but apart from a lack of suitable mounting points I was worried it might get snagged on something and put undue strain on the bumper.
I suppose I could get a short fabric strop and just extend one recovery point to just above the bumper, that would be fairly easy to secure with some shock cord.
Robin
  • DrRobin
  • Platinum Member
  • Platinum Member
06 Nov 2024 12:56 #258203 by DrRobin
I fitted a Jimnybits transfer case cover today.
It was fairly straightforward but the two bolts which pass through the frame/transfer case mounts weren’t the easiest to locate and tighten.
i only have the rear diff to do now, but that is back in my paint shed for a final coat.
Robin
  • DrRobin
  • Platinum Member
  • Platinum Member
06 Nov 2024 13:49 #258205 by DrRobin
I found a 550mm long soft shackle from Terrafirma, that might do the job
terrafirma4x4.com/tf3310xl.html
Available on eBay at £23 each.
  • DrRobin
  • Platinum Member
  • Platinum Member
08 Nov 2024 21:14 #258233 by DrRobin
The final part of my Reeth to Ripon tour, this time it is Arkleside, Dead Man's Hill, Scar Reservoir and In Moor Lane.
I go on a two day trip over the weekend, Stokesley to Reeth, no doubt more video reports will be on their way.
Robin
The following user(s) said Thank You: Lambert, gv42, Soeley
  • DrRobin
  • Platinum Member
  • Platinum Member
10 Nov 2024 21:52 #258253 by DrRobin
Another good weekend on the lanes with Trails and Tracks, this time N. Yorkshire Moors and another ‘Pot of Gold’ for my Jimny.
Then day 2 in the Yorkshire Dales and another go at Fremington Edge.
Robin
The following user(s) said Thank You: gv42, Soeley
