Icelandic Jimny
- Bradders91
- Thank you received: 10
23 Apr 2022 11:09 - 23 Apr 2022 11:39 #243081
by Bradders91
I posted in the wrong section originally (sorry!).
Here is my Jimny in Northern Iceland, I managed to roll my Hilux after importing it at HUGE expense and so I had to get something nice to replace it.... So I bought a Jimny after a few years away from owning them.
I put this one on 31s but it will go on 33s or 35s for next winter. We get HUGE amounts of snow here and so need large volume tyres to deflate to 5psi or less to get around.
Anyway I wanted to say hi and look forward to joining on the forum a bit
Chris
Icelandic Jimny was created by Bradders91
Chris
Last edit: 23 Apr 2022 11:39 by Bradders91.
- Dirtbird
24 Apr 2022 08:43 #243111
by Dirtbird
Replied by Dirtbird on topic Icelandic Jimny
Very Nice
- lookonimages
- Thank you received: 72
24 Apr 2022 19:59 #243134
by lookonimages
Replied by lookonimages on topic Re:Icelandic Jimny
awesome. like it !
- Ron0z
27 Apr 2022 11:30 #243169
by Ron0z
Replied by Ron0z on topic Re:Icelandic Jimny
I'm intrigued by the wheels. Or more specifically, what seems to be pipes or cables and what looks like a triangular piece mounted on the front wheel. Hard to see but is there something similar on the back wheel?
What's going on there?
- Thank you received: 2001
27 Apr 2022 12:31 #243171
Replied by Lambert on topic Re:Icelandic Jimny
That'd be the central tyre inflation system. Control tyre pressure on the fly. Very trick.
- Bradders91
27 Apr 2022 14:28 #243175
by Bradders91
Replied by Bradders91 on topic Icelandic Jimny
Yes exactly, it's tyre inflation. I have an ARB compressor under the bonnet that runs air to a control box with lines to each wheel.
I can use a control panel inside to deflate/inflate all tyres at once or any combination. Most people here have it linked to an app on their phone but this works just as well. The TMPS on each wheel still works so I can be pretty accurate.
Usually I just do it by eye as I'm never above 15psi in Winter and down as low as 5psi much of the time.
Time to create page: 0.245 seconds
