Red jimny fitted with full floating axles
11 Oct 2021 13:47 #239300 by Roger Fairclough
I am worried about the amount of unused thread on the nuts that secure the spacers to the hub.
Roger
11 Oct 2021 14:15 #239303 by LM42
The studs are standard length, the nuts supplied with the spacers are longer then the stud, ( actually longer then the nuts used with the OEM steel wheels)
Sent from my Redmi Note 8T using Tapatalk
11 Oct 2021 14:42 #239308 by Busta
Nice to see my "stick a bolt through the hub" vacuum hub bodge making an appearance there!
11 Oct 2021 16:40 #239318 by Roger Fairclough
The standard length stud is designed to fit the o.e steel wheel. You have now added the extra width of the spacer, approx 30mm. The wheel nuts that we can see should use all of the old studs and protrude about 1 thread beyond the nut. This is a safety issue and could easily result in the wheel tearing away from the hub.
Roger
11 Oct 2021 16:55 #239319 by LM42
There is as much thread being used here as the open nuts (OEM ) used on a steel wheel, the , the nuts pictured here are longer then the OEM open nuts , so there is less thread on a OEM open ended nut, so they also have a risk of tearing away as they have less thread to hold onto? The nuts used in the spacer to the wheel are closed nuts and cover the entire length of the exposed stud
Suzuki make alloy wheels that need extended shoulder wheel nuts , and they also use less thread then a steel wheel with open nut, and that's OEM fitment, from factory
11 Oct 2021 20:43 #239328 by LM42
Next job for the morning, thank you James
