South African jimny Build
  • Daniel30
31 Mar 2020 23:34 #220533 by Daniel30
Replied by Daniel30 on topic South African jimny Build
Very nice car, mods and scenery :)
01 Apr 2020 19:55 #220552 by RainerK
Replied by RainerK on topic South African jimny Build
Looks great!
If you drive through water, maybe you might want to add diff breathers.
The following user(s) said Thank You: Snazzy321
  • Snazzy321
02 Apr 2020 15:16 #220584 by Snazzy321
Replied by Snazzy321 on topic South African jimny Build
What exactly do they do? Ill read up a bit
02 Apr 2020 16:53 - 02 Apr 2020 17:02 #220589 by Scimike
Replied by Scimike on topic South African jimny Build
They reduce the possibility of water being drawn into the differential if you wade in deep water.
The differential heats up with use and any air inside expands and is expelled through a cheap one way valve on the top. When you drive into water you rapidly cool the differential, this causes a negative pressure inside that attempts to suck air (or water) back in. The breather kit replaces the one way valve allowing the differential to vent directly to atmosphere, and when the time comes to suck air back via a high mounted tube. It does this quickly, thus reducing the negative pressure while the axle is under water and the possible ingress of water.
Mike
Last edit: 02 Apr 2020 17:02 by Scimike.
  • Daniel30
02 Apr 2020 17:35 #220593 by Daniel30
Where did you mount the 9" speakers? Have you got a picture? :)
Time to create page: 2.222 seconds
