Ash's Brisk Blue SZ5 #395
- Ash97x
05 May 2019 11:12 - 05 May 2019 11:16 #207363
by Ash97x
Replied by Ash97x on topic Ash's Brisk Blue SZ5 #395
Andy, here’s hoping this post works.
You need to remove 3 x 10mm nuts from behind the light cluster you are working on. One’s in the wheel arch and the other two under the rear bumper.
Once you remove them, push the threads that these nuts were sitting on and the light cluster should ‘pop’ out. (Look at the build-up of dirt in mine already
To remove a bulb you just turn counter-clockwise and it’ll come away from the cluster, then pull off the electrical connector. Refit the new bulb. Better to test the bulb with the cluster off before refitting and finding out it’s faulty / not fitted correctly.
Refit everything back together and that’s it done! Here’s a comparison of the bulbs. Left stock and right the new LED.
Hope this helps, cheers Ash.
EDIT - Procedure is the same for both light clusters, the reversing light is located in the LHS cluster and the rear fog the RHS/DS cluster.
)To remove a bulb you just turn counter-clockwise and it’ll come away from the cluster, then pull off the electrical connector. Refit the new bulb. Better to test the bulb with the cluster off before refitting and finding out it’s faulty / not fitted correctly.
Last edit: 05 May 2019 11:16 by Ash97x.
- Andy2640
05 May 2019 11:16 - 05 May 2019 11:17 #207365
by Andy2640
Replied by Andy2640 on topic Ash's Brisk Blue SZ5 #395
Your awesome Ash mate
:silly:
:silly:
Last edit: 05 May 2019 11:17 by Andy2640.
- stiffsteve204me
05 May 2019 11:17 #207366
by stiffsteve204me
Replied by stiffsteve204me on topic Ash's Brisk Blue SZ5 #395
Ash.
Thank you for posting this info.
I know that you replaced the reversing light bulb with a led. Have you found it to be a noticeable improvement, in practice?
Steve.
Steve.
- Ash97x
05 May 2019 11:21 #207368
by Ash97x
Hope it helps Andy! I must say the rear fog change-out isn’t a necessity, but the stock reversing light is terrible IMO. I got bored so I changed both ha.
Ash
Replied by Ash97x on topic Re:Ash's Brisk Blue SZ5 #395
Andy2640 wrote: Your awesome Ash mate
:silly:
:silly:
Ash
- Ash97x
05 May 2019 11:24 #207369
by Ash97x
No worries Steve, happy to help and enjoy posting a wee procedure on different mods etc. Just noticed your reply there after I posted to Andy, the difference is huge between the stock reversing light and the new LED. I never took pics to compare but it’s day & night so to speak. Have heard the LED can cause glare on the reversing camera (if fitted) but don’t have it to test this theory.
Cheers Ash
stiffsteve204me wrote: Ash.
Steve.
Cheers Ash
- Ash97x
05 May 2019 11:38 #207372
by Ash97x
Time to create page: 0.250 seconds
