Re:Gadget's 2019 hearing aid SZ5
10 Jun 2019 17:12 #209809 by Gadget
Fixed one of the things on my minor annoyances list. The lack of power to 12v accessory or USB sockets when the ignition is off prevents you from charging your phone when camping unless you have the car turned on.
I fitted a combined USB port/voltmeter into the blank for the JDM start button. The space could have been made for it! :)
Part used: www.amazon.co.uk/gp/product/B07F8R9F6L/r...00_s00?ie=UTF8&psc=1
  • stiffsteve204me
10 Jun 2019 17:25 #209811 by stiffsteve204me
Replied by stiffsteve204me on topic Gadget's 2019 hearing aid SZ5
Gadget wrote: Fixed one of the things on my minor annoyances list. The lack of power to 12v accessory or USB sockets when the ignition is off prevents you from charging your phone when camping unless you have the car turned on.
What a good idea, Gadget. :woohoo:
Were did you connect to?
Steve.
10 Jun 2019 17:42 #209815 by Gadget
I used to included earthing strap to connect to the far end of this bolt:
The bolt screws into a fixed retaining nut, but enough thread protrudes to hook on the earthing loop and add a washer and M8 nut. I needed to file the earthing loop slightly so that it was large enough to slip over the bolt. This pic shows the earthing loop secured.
I wanted to take a live feed direct from the battery, but the grommets between engine bay and interior are almost impossible to breach, so ran a 17amp wire behind the edge of carpet across both footwells and into the fusebox in the passenger footwell. Used an Add-a-Circuit (mini LP) and piggybacked off fuse 5 (perm live 20amp), adding a 10amp fuse for the new circuit which matched that supplied.
The following user(s) said Thank You: stiffsteve204me, johnjohanaphy
  • Daniel30
10 Jun 2019 18:00 #209817 by Daniel30
Replied by Daniel30 on topic Gadget's 2019 hearing aid SZ5
Nice job
10 Jun 2019 18:16 #209820 by Lambert
That's neat.
The following user(s) said Thank You: Gadget
  • Andy2640
11 Jun 2019 03:31 #209834 by Andy2640
Replied by Andy2640 on topic Gadget's 2019 hearing aid SZ5
Your thread gets better all the time.
Great idea and jicely executed
Time to create page: 0.219 seconds
