I present you my Jimny - Advice needed!
13 Feb 2019 06:38 #203083 by Lambert
Agreed. You could do a lot worse than putting it back to the standard suspension and a set of suitable tyres for the prevailing terrain. It might not get absolutely as far down a forest track as it could potentially like it is in the pictures but it will be much more user-friendly.
The following user(s) said Thank You: burnazores
  • burnazores
13 Feb 2019 09:28 #203095 by burnazores
Replied by burnazores on topic I present you my Jimny - Advice needed!
Thank you for the replies.
I have a shopping cart with standard spec KYB springs and Monroe shocks, together with some additional maintenance items. Still deciding on the tyres...
I am looking at the Maxxis M8060 205/70 r15 mounted on the current rims.
Do you think these would fit well in the 7" wide rims?
Also, do you think it will look ok with the big arches? I have spacers installed, but I don't know how thick they are...
Any suggestions on tyres (muds preferably, but some aggressive A/T could work.
Thanks!
13 Feb 2019 11:07 #203100 by Lambert
A 7 inch rim is plenty wide enough for a 205 bot won't be a problem. Not used the 8060 but the maxxis buckshot is a good tyre so can't see there being a problem there either.
13 Feb 2019 12:02 #203108 by sniper
I have KYB road springs fitted with 15mm seats. They have proved to be very good, both on road and off.
They have only been in for about 5k miles but have no sign of softening despite some pretty hard off road work.
After spouting their merits, they are being changed today for some Eibach pro-lift +30mm....... I have found myself doing a little more off road than I first envisaged, I want just that little more off road but I don't want to lose road manners.
The Monroe dampers have been positively received by other forum members.
Depending on the cut of your tyres, you may find the spacers need to be removed to avoid catching.
Good luck,
sniper
13 Feb 2019 12:05 #203109 by sniper
Sorry just looked at your arches again..... your fine.
sniper
  • burnazores
13 Feb 2019 14:08 #203121 by burnazores
I am more worried that i ends up looking ridiculous... (disproportionete)
Time to create page: 0.559 seconds
