Daz's 2019 SZ4
23 Jan 2019 10:51 #201503 by saxj
Replied by saxj on topic Daz's 2019 SZ4
The door seals are not as good as the old one. So if you do any wading, you better keep moving.
23 Jan 2019 11:27 #201506 by mlines
Replied by mlines on topic Daz's 2019 SZ4
TaterTot wrote:
Daz3031 wrote: Yay... snow! :)
I got to try out 4 wheel drive for the first time in my way to work this morning.
The fogged up windows, is that also pretty normal on the new Jimny?
Based on the test drive one we had, yes.
We had it for two hours and had a play with the aircon etc but still had misting around the edges until we cracked open the drivers window (so pretty much standard for a Jimny!).It was not on "re-circulate", but it was a rainy day and we had wet coats on.
23 Jan 2019 12:11 - 23 Jan 2019 12:12 #201509 by saxj
The top spec model does have the one button front demist feature though, which is handy.
Last edit: 23 Jan 2019 12:12 by saxj.
  • TaterTot
23 Jan 2019 16:05 #201515 by TaterTot
Replied by TaterTot on topic Daz's 2019 SZ4
Thanks. I have this "issue" on my current Jimny. Especially in winter. It's enough that I think about taking a shower after the drive, wham foggy. My solution to that issue was getting a chemical dehumidifier (those stand alone little boxes, with pellets in a bag inside), that are common on sailing boats. It works pretty well. And the water doesn't evaporate because of the fancy chemical in the bag. Didn't think of that the first time I poured it out....
24 Jan 2019 03:37 - 24 Jan 2019 03:38 #201586 by Max Headroom
Replied by Max Headroom on topic Daz's 2019 SZ4
TaterTot wrote: My solution to that issue was getting a chemical dehumidifier (those stand alone little boxes, with pellets in a bag inside), that are common on sailing boats. It works pretty well. And the water doesn't evaporate because of the fancy chemical in the bag. Didn't think of that the first time I poured it out....
I have a 'bandolier' of eight bags of silica-gel - each bag is about half the size of a bag of sugar. (they're used when we 'bag-up' aircraft engines for transportation, but many of the used bandoliers get chucked out), They will re-cycle and you can satisfactorily dry them out on a radiator or oven on low its lowest setting.
I drape mine across the top of the dashboard,and it works very well.
Wifey doesn't like me draping it over the radiators in the house though
Last edit: 24 Jan 2019 03:38 by Max Headroom.
  • Daz3031
26 Jan 2019 16:46 #201754 by Daz3031
Replied by Daz3031 on topic Daz's 2019 SZ4
Rear wheel centre caps fitted - finishes the wheels off nicely.
Time to create page: 0.288 seconds
