Blue Jimny 2019
  • ColdFire
25 Jan 2019 11:44 - 25 Jan 2019 20:30 #201662 by ColdFire
Replied by ColdFire on topic Blue Jimny 2019
The screen just fits and comes with everything needed. I think for the camera any aftermarket camera can be fitted. For the steering wheel controls you will need to use an app within the screen to sync the control with the new screen. It doesn't use can-bus connection.
It can be purchased thru aliexpress. i got it thru
www.astral-elec.com/2019-suzuki-jimny-in...adio-for-suzuki.html
Few things to keep in mind. It will fit the Jimny that comes without a screen from factory. Also for carplay you need to specify and pay additional 20$ or something like this.
Last edit: 25 Jan 2019 20:30 by ColdFire.
  • lee1980
25 Jan 2019 13:21 #201671 by lee1980
Replied by lee1980 on topic Blue Jimny 2019
That is awesome for the SZ4 base model, nice to know its quite easy and sure more different ones will come out in time!
  • tim04
25 Jan 2019 14:57 #201675 by tim04
Replied by tim04 on topic Blue Jimny 2019
Thanks for the info, that's really helpful. I will definitely be replacing the CD/radio asap with a screen and car play.
Any idea how the existing stereo is removed as I can't see any screws/clips?
Thanks
  • ColdFire
25 Jan 2019 19:49 - 25 Jan 2019 19:55 #201698 by ColdFire
Remove the plastic trim underneath the screen with plastic trim remover tool. You will see two screws that holds the Radio/CD. After removing the two screws try to pray on Radio/CD unit and it will pop off as it's held by clips.
Last edit: 25 Jan 2019 19:55 by ColdFire.
  • ColdFire
25 Jan 2019 20:03 #201700 by ColdFire
Few comments on the Operating system. It does kick you off playstore and carplay sometimes. Annoying to be frank but better than having no screen for sure.
I would say there are other options available in Japan in which you can buy a surronder/trim to fit other screens from Pioneers and Kenwood etc... depends which way each one want to go.
  • tim04
25 Jan 2019 20:05 #201701 by tim04
Thanks for the info. I had a look at double din units here in the UK today (Sony/Pioneer? - not cheap but worth it to have the added functionality.
Time to create page: 0.306 seconds
