New member with thanks
  • Cranfj
  • Visitor
  • Visitor
09 Sep 2018 07:25 - 09 Sep 2018 07:32 #195805 by Cranfj
New member with thanks was created by Cranfj
Morning all,
I'm new to the forum and joining to thank you for the technical information I have harvested and used as a guest since buying my first jimny two weeks ago.
That includes:
- Towbar fitment and wiring guide, which worked perfectly.
- Rear seat removal.
- 4 wheel drive diagnostics! Investigation found vacuum pipes the wrong way around on the offside locking hub.
My Jimny is a 2001, 106k mikes, with no service history, so I am building the courage to tackle the cambelt next.
Best,
Cranfj
Last edit: 09 Sep 2018 07:32 by Cranfj. Reason: Adjusted for privacy
09 Sep 2018 08:29 #195806 by sniper
Replied by sniper on topic New member with thanks
Welcome, tech info and advice is great, some very helpful people too.
sniper
  • jonnz
  • Visitor
  • Visitor
09 Sep 2018 09:21 - 10 Sep 2018 05:44 #195807 by jonnz
Replied by jonnz on topic New member with thanks
Did my first ever cambelt change in a car on my Jimny (1998 G13BB) about 4 weeks ago. Just follow the factory service manual and take it slow. Only mess up I had was after replacing crankshaft seal, when I noticed that its spring had dropped off and was laying on the ground, I tried to carefully remove the new seal and wrecked it completely.
Last edit: 10 Sep 2018 05:44 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
09 Sep 2018 16:06 #195818 by 1390_taz
Replied by 1390_taz on topic New member with thanks
Welcome to the forum. Very knowledgeable bunch
  • Cranfj
  • Visitor
  • Visitor
09 Sep 2018 19:02 #195820 by Cranfj
Replied by Cranfj on topic New member with thanks
Thanks all.
Jonnz, Is the factory service manual mentioned available online?
Did you choose to replace the crankshaft oil seal or is it an essential part of the procedure? I've heard they're hard to get right.
10 Sep 2018 05:45 #195832 by Lambert
Replied by Lambert on topic New member with thanks
Time to create page: 0.156 seconds
