2004 Jimny with 50mm spring lift and BFG 235/75-15 All Terr
- 04JimnyNorwegianGuy
- Visitor
14 Apr 2017 13:56 - 14 Apr 2017 14:03 #180240
by 04JimnyNorwegianGuy
2004 Jimny with 50mm spring lift and BFG 235/75-15 All Terr was created by 04JimnyNorwegianGuy
Planning to build some bigger lift and put on bigger tires sometime later. But understand that it will require Rock lobster or at least a modification on exsisting transfer. Well here is my car as it looks for the moment
Last edit: 14 Apr 2017 14:03 by 04JimnyNorwegianGuy.
- 1066Boy
- Visitor
14 Apr 2017 17:15 #180244
by 1066Boy
Replied by 1066Boy on topic 2004 Jimny with 50mm spring lift and BFG 235/75-15 All Terr
Welcome to the club.
- Visitor
14 Apr 2017 18:28 #180245
Replied by Daniel30 on topic 2004 Jimny with 50mm spring lift and BFG 235/75-15 All Terr
Welcome
- Visitor
15 Apr 2017 21:13 #180272
Replied by 04JimnyNorwegianGuy on topic 2004 Jimny with 50mm spring lift and BFG 235/75-15 All Terr
Ordered 2" body lift today
Looking for a rocklobster transfer. Rockwatt (or something like that) make them i UK I understand. Thats not to far from Norway. Any other ideas of getting that kind of transfer ?
The preferable gearing would be?
Planning on running offroad with existing 235/75-15" but maybe 32 or 33" onroad for showing off
Actually the existing tires setup with 2" spring lift works fine offroad with stock transfer ... but swaybar is not disconnected ....And im not doing extreme offroading with this setup, but it climbs very good. Keep track with the wranglers and cherokees with som minor lift on. Even climb better than them (due to much lower weight?) Could need som lower gearing though
15 Apr 2017 23:57 #180273
Replied by Riccy on topic 2004 Jimny with 50mm spring lift and BFG 235/75-15 All Terr
Hello and welcome along,
A Rockwatt 'rocklobster' is a high quality remanufactured SJ transfer box, it has 1.5 in high box (vs standard 1.32) and 4.3 in low box (vs ?im unsure). these are lower ranges by 6.9% in high-box from a standard stick shift transfer box.
A mini -lobster is essentially just an SJ box which has the same 1.5 drop in high box, but not as low in low-box.
Both rocklobster and mini-lobster will require different front and intermediary props to fit the t-box.
Your 235 tyres are 6% larger than standard, so a rocklobster box would be good for normal road driving, and great off-road. it would also allow you to run larger tyres to 'show off' as well
I have one going spare (and all props & bucket/bushes to fit it), but i dont know about postage to Norway? Im after £500+postage for the full kit. It was made for a 2004 M13 (non VVT) with an R7me gearbox and existing stick-shift transfer box. A donation to running of the forum from any sales also of course
oh, and pics of progress are compulsory. Jimnys are very addictive!
Riccy.
Riccy.
- Visitor
16 Apr 2017 00:23 - 16 Apr 2017 00:45 #180274
I dont know about the postage either. I dont know where in the world you're living as well?
My english is a little poor. Maybe you alredy mentioned without me understanding ....but is the lobster with the mounting brackets ?
I found a sj 410 and also a sj 413 transfer here in Norway ...but do not posess the skills to do the convertion
For the moment I honestly dont know if I have the vvt engine or not. Also dont know what kind of gearbox ...
Used to have Jeep Wrangler and Cherokee. Became a hobby-expert on those. Hope to accumulate skills on my Jimny day by day.
Last edit: 16 Apr 2017 00:45 by 04JimnyNorwegianGuy.
Time to create page: 0.160 seconds
