Newbie post. Just aquired my first Jimny
- DINGLE287
27 Jan 2017 23:04 #177396
by DINGLE287
Replied by DINGLE287 on topic Re:Newbie post. Just aquired my first Jimny
Thanks wilku. Tbh tho I will probably use mech oil, duck oil or whatever spray I have at the yard handy, and will most likely copper grease most threads that are disturbed during work.
Thanks for the tip on the shocks. Looks like a cheapy spacer kit for now then. £300+ for springs is a bit out my budget at moment combined with buying tyre's and other nik naks needed. I might consider a body lift as well to help with tyre size, but need to do more research to see what complications are involved
Sent from my SM-N9005 using Tapatalk
- 1066Boy
28 Jan 2017 09:17 #177402
by 1066Boy
Replied by 1066Boy on topic Re:Newbie post. Just aquired my first Jimny
No point in going above 2" spring lift unless you are fitting large tyres. 3"+ you will need lots of extra bits to do it
properly and then with larger tyres, a change of the transfer box to correct the gearing.
All depends how much you want to spend. :woohoo:
- DINGLE287
28 Jan 2017 12:26 #177409
by DINGLE287
Sorry should of mentioned I only want 2" suspension lift. The extra work involved to go more is way beyond my budget and time available to work on it. Plus I need to keep decent road manners as well. I was hoping for 235.75.15's but it's looking like they will be a bit much. So now I'm aiming for 215's with a 2" spring spacer kit (hopefully will be enough) with castor correction to keep road manners. And possibly a 2" body lift shortly after, but I need to sit down and work out exactly what it entails before opening a can of worms. The bush kit is easy enough, and I can handle lengthening gear sticks etc. Just worried about pipes and cables and any other obstacles
28 Jan 2017 14:01 #177413
Replied by jackonlyjack on topic Re:Newbie post. Just aquired my first Jimny
body lift will only require steering spacer from bits4vits/jimnybits
also extended brake lines from llama4x4/jimnybits
and bits4vits sell nice poly body lifts
Jack
Jack
- DINGLE287
28 Jan 2017 16:13 #177418
by DINGLE287
Ahh right thanks Jack. That's conflicting then. As I thought no steering extension was needed for 2"
- wilku
28 Jan 2017 18:53 #177439
by wilku
Replied by wilku on topic Re:Newbie post. Just aquired my first Jimny
Because it isn't for the suspension lift. It is necessary (although not in all cases I believe) for a body lift. And definitely it will be needed for a suspension & body lift combined.
Time to create page: 0.192 seconds
