Lag, Shield or Re-locate
- ZookFastback
- Visitor
01 Jan 2017 01:20 #176136
by ZookFastback
Lag, Shield or Re-locate was created by ZookFastback
Since fitting the headers (Extractors) to the G16B 1600 engine in my Jimny, I've noticed how hot it gets under the bonnet. Matter of fact, the overflow bottle is starting to melt on the outside nearest headers. Engine temp is normal and the new aluminium radiator has 3 cores instead of the original 2.
So, should I lag the headers, or build a shield or re-locate the overflow bottle? There is a 1" clearance from overflow bottle to headers at nearest point.
- 1066Boy
- Visitor
01 Jan 2017 08:48 #176139
by 1066Boy
Replied by 1066Boy on topic Lag, Shield or Re-locate
I would lag them, it made a big difference on my mates trike.
![:) :)](/media/kunena/emoticons/8.png)
- ZookFastback
- Visitor
01 Jan 2017 08:58 #176140
by ZookFastback
Replied by ZookFastback on topic Lag, Shield or Re-locate
- gusthegorilla
- Visitor
01 Jan 2017 09:23 #176142
by gusthegorilla
Replied by gusthegorilla on topic Lag, Shield or Re-locate
Forum member Keithy does an exquisite line in bonnet ventilation, developed to dramatically increase heat extraction following turbo installation. ...I've seen them first hand and they really are good.
Keith....you might send Ian a few pics...
![;) ;)](/media/kunena/emoticons/11.png)
- 1066Boy
- Visitor
01 Jan 2017 09:51 #176144
by 1066Boy
That made me laugh, the bloke in the picture is about the same size as him. :laugh:
The trike runs a big V-twin motor and the pipe from the front cylinder runs just inside your right leg. :evil:
ZookFastback wrote:
1066Boy wrote: I would lag them, it made a big difference on my mates trike.
For some reason, when you said the above, this is what came to my mind... :woohoo:
01 Jan 2017 12:26 #176149
by Keithy
![B) B)](/media/kunena/emoticons/1.png)
I think there are pictures in the turbo jimny thread?
I've moved my washer jets onto the wiper arms so I need to make a new set.
My vents weren't really to cool the headers just to allow air easier passage through the radiator..... abelt and braces approach.
Lagging will cure the boiling the water in the washer bottle problem....and all the under-bonnet heat trying to melt everything.
Bearing in mind it merely passes the heat further down the line so check the other heat shields are in place.
Replied by Keithy on topic Lag, Shield or Re-locate
If he pays the postage he can have a set!gusthegorilla wrote: Forum member Keithy does an exquisite line in bonnet ventilation, developed to dramatically increase heat extraction following turbo installation. ...I've seen them first hand and they really are good.
Time to create page: 0.153 seconds
