My Jimny named R&B
03 Aug 2018 15:52 #194813 by sniper
Replied by sniper on topic My Jimny named R&B
R&B looks well with them on pal, a bit of grinding and a bit of welding.....
It looks quite easy to triangulate / support the mount and allow you to cut away the projection, what an MOT inspector will say I don't know.... I can cut and prep the plates but can't weld anymore. Local garage will weld it for £80 if needed, they are testers too so I can have a word about welding around the mount, again if needed.
sniper
03 Aug 2018 16:46 #194814 by Riccy
Replied by Riccy on topic My Jimny named R&B
I put a ratchet strap around the body mount's two sections and squeezed them together a bit (maybe 1" all together).
Also installed some sexy rockwatt extended bump stops, which seemed to help just as much with the same problem.
What size are they? look great on the GV rims :-)
03 Aug 2018 20:01 #194816 by jackonlyjack
04 Aug 2018 06:12 #194819 by Riccy
so thats a 29.3" tall by 8.9" wide tyre then, compared to the 31x10.5 i have, i am surprised you have a problem with them catching.
Different rims, offset and lift maybe? for reference my rims are 15x8 et -0, theres 30mm wheel spacers and 4.5" lift on the springs
04 Aug 2018 07:13 #194820 by jackonlyjack
Replied by jackonlyjack on topic My Jimny named R&B
Could be that i have 3" castor arms with a 2" lift. Therfore the axle is pushed forwards
Being over casterd it drives so nice
I have got 4 Honda crv springs so i can go up some
04 Aug 2018 07:46 #194821 by Riccy
That will explain it then! I too have 3" castor arms, which will be pulled back by inference then
Time to create page: 0.170 seconds
