Dan's Blueish Black
  • Daniel30
24 Jul 2016 17:29 #170461 by Daniel30
Replied by Daniel30 on topic Dan's Blueish Black
;) get the chrome ones you can't see them in the indicator ;)
  • Daniel30
24 Jul 2016 18:21 #170466 by Daniel30
Finally fitted some HD tow points to the Jimmy last week :)
After getting the usual great info from the forum i set about installing some front HD tow points, off came the bumper which was ok until i got to the three stooges at the bottom of the bumper that wouldn't move even with a impact driver so a soak in wd40 (a cup of tea and a scratch head) and then a phillips head that fitted snug on the end of a large ratchet and eased them off slowly undoing then tightening a little bit same again with some wd40 again until they came off manage to get all three off safely :)
[IMG
i don't know if i just didn't get all the instructions included but i only got one sheet so just kept offering the tow points up to the Jimmy until they looked/fitted right one side needs the crazy bolts and nuts placed in it so you can fit a certain side as it covers up the opening
[IMG
Once you have worked it out its a matter of marking the holes 5 each side then drilling not forgetting the eye ware!!!!!!!! :silly: first a pilot hole then i used an 11mm bit the bolts fitted nicely
[IMG
and for a while now i wanted to chop the bumper so while the front fog part was out and i could see more of an idea what it would look like i got a push from my eldest daughter to cut the bumper :woohoo: :silly: :woohoo: used a slitting disk and angle grinder which worked quite well also trimmed down the front fog part so it hides the metal area like asked plate purely for cosmetic use only B) then today i treated her to a bit of a wash and wax B)
[IMG
  • Daniel30
26 Jul 2016 12:10 #170548 by Daniel30
Had these rubber brackets for a while in the intent to fit a small spade to the inside of the back door when i was in tool station the other day there was a special on them so i bought one it was about £8 odd, so off came the rear door panel as superbly detailed by Halford when he was having trouble with his rear wiper and needed to get the panel off.
Popped down to Halfrauds for a couple of nuts and bolts got some 6x20mm bolts and some nylock nuts drilled two 6mm holes and attached the rubber brackets put the spade in and job done B)
[IMG
[IMG
[IMG
26 Jul 2016 19:10 #170578 by Halford
Replied by Halford on topic Dan's Blueish Black
Looks good Dan
Like those rubber clamps
Plenty room left to fit a machete :whistle:
  • Daniel30
26 Jul 2016 19:17 #170581 by Daniel30
Thanks Halford I'll need a machete to spread that lovely jam that I know I'm going to win :woohoo: :evil: :whistle: especially as Gus is out of the competion Now :whistle: :evil:
  • gusthegorilla
26 Jul 2016 19:26 - 26 Jul 2016 19:30 #170584 by gusthegorilla
Replied by gusthegorilla on topic Dan's Blueish Black
Daniel30 wrote: Thanks Halford I'll need a machete to spread that lovely jam that I know I'm going to win :woohoo: :evil: :whistle: especially as Gus is out of the competion Now :whistle: :evil:
Am I missing something here???
How do you figure that, Daniel...... :unsure: :unsure: :whistle:
EDIT Ok, just worked it out........don't you worry, mate....we Northerners stick together, and I'm still in.... :whistle: :whistle:
Last edit: 26 Jul 2016 19:30 by gusthegorilla.
